Hello Lebrat,
It depends...
You will get the best cycle life from your cells if then end up with a resting voltage of around 3.5 volts.
If you work at it, and end up with lower resting voltages in the 2.5 -2.999 volts, it is best to start the charge at around 100 mA until the voltage is back up above 3.0 volts. Then you can proceed at a normal charge rate.
This is a gray area. Different brands of cells respond to over discharging differently, so there is no hard fast rule. However, if you end up with a resting voltage of around 3.5 volts, no special precautions are required during charging.
Tom
