AlexGT
What gives? It went dead on the FIRST charge?
Just recieved it from DX its the model DX8683, started voltage at 4.02v out of the wrapper, started charging at 400mah and when it hit 4.25v I disconnected and put it in my Jet II Pro, press the switch and nothing!
I pulled it out and tested it with the charger's voltmeter and it shows 0.00v! I'm like WTF! then I test the other 3 TF's that came with my order and had just charged fine up to 4.23v and all read 4.15-4.19v and work just fine in the JB light.
I used a needle to pick right thru the protective envelope and test voltage, and sure enough the dead battery reads 4.11v, so I think the PCB went kaput! How can I revive it? or just throw it away or make fun experiments with it?
Thanks in advance for your suggestions
AlexGT
AlexGT
