balrog
Re: Pila 150S bodies (E series compatible)
I received the prototype today. At the speed they are going I might have the bare aluminium bodies ready to send before I go away. I've checked that it works with all the different heads and tailcaps that I've had and there have been no problems. I've approved it with some minor changes and they are going to start the run. The only change of note is to increase the inside diameter ever so slightly since the Pilas are slightly wider than the 123s. I don't want any chance of any of them not fitting into the body with ample room for it to easily slide out again.
It's actually a really comfortable size IMO. Fits snugly in my hand and with the lack of a pocket clip it is more comfortable than the E1e or E2e. It fits okay in the pocket but I reckon it's too big to EDC. Enough typing. Below are some pictures. Sorry about the low light levels in the photos. If I had the flash on the body ended up looking like it was white due to the reflection.
First, size comparison against E1e and E2e with McLux heads.
The appearance of the prototype body is not how it will be on the final body. The prototype was done by hand to check fit and function. The aesthetics weren't considered. You can see three crappy test knurls around the 150S body. The final bodies won't be knurled using a knurling tool. The knurls will actually be cut by a tool with a single pointy tip that will move across the body as it spins round to cut the spirals into the metal. Also, the flange near the head is not as curved as it is on the SureFire bodies. The final products will have a curved flange to match the SureFire bodies.
A pic with the KL4 head on it, next to an E2e + KL1.
This time with the bare aluminium McLux PR and a satin grey LOTC.
Finally, proof that it actually works. /ubbthreads/images/graemlins/smile.gif
