Battery Research Base. Handbook of Batteries.
VladimirT
Hello. My name is Vladimir, I want to show you my website https://batteries.wiki/
This site is the batteries guidebook and a space for batteries tests.
I spent several months of work and a lot of money buying batteries and equipment.
I did tests of over 300 batteries. More than 2000 tests in total.
I also had to write many lines of code to implement the database.
There are the functions available on the site:
1. Batteries can be selected according to specifications. You can also sort the data and search.
2. You can compare the specifications of different batteries
3. You can compare the measurement results
4. You have access to dynamic charts in JavaScript
5. I also do resource tests
6. I check for lost capacity during storage
7. I also check the batteries operation at low temperatures
I hope my work will be useful to the community.
Specifying what your test cutoff parameters are would be good.
I am questioning the huge difference in 1a 'd' cell capacity between duracell and energizer.
