moldyoldy
For those of you with an interest in battery technology, a recent article in "Der Spiegel" issue 2007-48 (A German weekly) gave some remarkable datapoints on energy efficiency. For those of you who wish to read the original article in German, check out http://www.spiegel.de/spiegel/0,1518,519773,00.html.
For my own use, I am slowly making the switch from NiMh to Lithium-Ion rechargeable technology. slow because of the investment in Ni-Mh chargers and cells.
The essence of the opinion expressed in the article is that electric drive is the future of vehicle drive systems, not any piston-driven system, be it diesel or gasoline. Some interesting data points roughly in order of appearance in the article. ((parentheses indicate my input))
- A diesel engine converts about 1/3 of the available (hydrocarbon) energy into drive power. ((gasoline engines are less efficient)).
- An electric drive converts a very high percentage of the provided electrical energy into drive power. ((and with high torque))
- the primary failure of electric cars in the current market is due to the short range, currently only about 50 km, and a charge time of hours.
- many firms have been working for over 10 years on a roundabout method of generating electricity with hydrogen as the energy carrier. A hydrogen fuel cell drive system can achieve several hundred km range.
- The primary inadequacy of the fuel-cell drive system is due to the excessive energy expended in generating hydrogen to be converted back to electricity. With a hydrogen fuel cell system, only about ¼ of the original electrical energy is delivered to the drive wheels. Half of the original electric energy is lost in creating hydrogen. Half of the resulting hydrogen energy is lost in the reverse conversion of hydrogen back to electricity on board a vehicle. worse still, the storage and transport of hydrogen is expensive due to the storage characteristics of hydrogen.
- The efficiency of a modern coal-fired power plant is about 45%. ((steam turbine systems))
- Natural gas-fired power plants with heat recovery systems can reach 90% efficiency.
- Losses in charging and discharging "modern" batteries lies in the single digit region. ((unspecified which battery type))
- Lithium-Ion batteries are taking over in many areas be it mobile telephones, laptops, model airplanes.
- For upcoming electric cars, VW is planning on it's "up!", a longer version called "space up!". Mercedes will bring out an electric "SMART". GM is planning on a compact car already shown as an Opel by the name of "Flextreme".
- Nevertheless the current data shows the limits of batteries. The GM vehicle has 180 kilograms of Lithium-Ion batteries which generate 16KWH of electricity. That is corresponds to the energy in 2 liters of gasoline. However in an electric car, that 16KWh gives a range of about 150km when driving moderately with a top speed of about 120km/h (75mph). Unfortunately the electric power required is more than a standard house mains outlet can provide. The researchers are trying for a cycle life of 3000 cycles corresponding to a 10yr lifetime. For the time being in current prototype autos from VW and GM, an internal combustion engine provides the necessary current for long distance driving. In normal commuter traffic, the current available in a normal house is sufficient to keep the batteries charged
- Li-Ion batteries cost about 1000 Euro per KWH with a price drop expected for production quantities
- German household electric costs are about Euro 0.18 per KWH. ((In Minnesota, it is about $0.08/KWH)). The resultant electric car operational costs for 100km would be about 1.5 Euro or about 10x less than a gasoline or diesel motor system costs in operation.
- Safety is still of great concern for use of Li-Ion cells with their large energy content. The plastic separator between the anode and cathode melts at about 140 deg C and then the battery gives off its energy in flame. If this event occurs with a 16KWH Li-Ion battery, there is a serious life danger for several meters around. Because of this danger, the use of Li-Ion batteries in cars is being delayed. Most manufacturers are considering the use of small Li-Ion battery packs. Tesla uses 7000 laptop-cells to drive its' E-sports car although that is a bit daring and not ready for large serial production.
- overcharging is a still a problem as many owners of small devices have found out.
- A breakthrough is possible ((for Li-Ion cells)). Chemists have developed a flexible ceramic separator which withstands up to 450deg C. Overcharging this cell leads only to venting. Another test was to drive a nail thru the cell. In a normal Li-Ion cell, it would have exploded in flame w/in seconds. With the ceramic separator it only lost its' charge.
Notes from an earlier Spiegel magazine article:
- the efficiency of the German train system with electric drives results in an equivalent efficiency of about 2.5 liters of "fuel" per 100 km. Most European cars are still hoping to consume less than 5 liters of fuel per 100km. ((47.5 mpg or so)).
