Batuca Battery Cases - where to buy? Do they fit Into Otter/Peli Cases?
Doug
SoCal
I was wondering if a pair (or just 1) Batuca case would fit into a Pelican or Otter case.... has anyone tried this? Got pics? Thanks!
Doug
Re: Batuca Battery Cases, Do They Fit Into Otter/Pelican Cases?
just tested this for ya
a double batuca does fit in a Pelican 1010 just barely BUT you have to remove the rubber lining which means it wont be waterproof. a single batuca fits just fine.
why would you want to do that though? just get a piece of foam, fit it into the case, and make holes the batteries? anyways, there ya go!
How would removing the rubber lining make the case no longer waterproof?
The idea is to have something to hold batteries, that I can break down, and put into something smaller as needed.... So, if I need to take them, and put them in something that might get wet, crushed, I use the pelican case, if I just need 4 batts, I take one half of the Batuca's... does that make sense?
What are the dimensions of the 2 Batuca cases together? Thanks.
Rubber lining acts as a gasket. You'd have to see one of the cases in person to understand.
My 1010 case dose not have a rubber lining, just a foam pad and a o-ring!
4-1/2" L x 2-3/4" W x 7/8" D. A single Batuca is a tad over 2-1/4" L.
Where To Buy Batuca Battery Cases?
Besides tadgear, where is another place to buy theses cases, they seem to be hard to find, wel, at least in clear! Thanks...
Doug
Looks like they should fit into a 1010 case... I guess I will just have to get them, and try them in a 1010 case.... Thanks Codeman...
Doug
Re: Where To Buy Batuca Battery Cases?
I get mine from bugoutgearusa.com - Flavio is great to deal with (plus, there's a CPF special discount; check my sigline for details)
It was not necessary to start a second thread on this. I am merging them.
Not see the Batuca... thanks anyways...
Any discount codes for tadgear?
