shifty: The LS is AA'ed to the McModule and the BB750 circuit is potted with AA to the walls of the McModule so there should be enough thermal path for the heat to dissipate. /ubbthreads/images/graemlins/icon23.gif
ticey: I know ticey, this shouldn't be happening. I used the tip of the AA stirer to make sure (as much as practicable) that there are no air pockets in the AA. Yeah, I have the board with I haven't installed yet connected to power and a LS and powered it up. After a 10-15sec, the light would go off. I touched and smelt the copper heatsink and it is smokin' hot. Definately too hot to touch for more than 1 sec. I am at a loss too. /ubbthreads/images/graemlins/icon3.gif
doug: Yes Doug, a huge load of current is being pushed through the little LTNH IC and all the components on the circuit. As you say, in isolation, this circuit would not be a viable driver for a LS. The circuit is definately being maxed out. That's why I used AA as suggested by all.
ticey: "Too high a Vf?"... actually ticey, it is an X3T /ubbthreads/images/graemlins/smile.gif
dat2zip: Wayne, I heatsinked the top of the IC and the diode to promote a larger area for the heat to leave the circuit and move onto the AA onto the McModule. That would surely aid, rather than impede the heat transfer. /ubbthreads/images/graemlins/smile.gif Most people just pot the top of the circuit. I thought I would go for the 'overkill' option.
Also as mentioned above, the entire circuit has AA on it... right to the top of the McModule where the anode cap sits. I don't know what else I can do. Also the circuit that I haven't installed in the McModule also exhibit the same shutdown behaviour. That also has the heatsink on the IC and diode. I don't have a fan on whilst testing it so it did get very hot quickly. That shouldn't be happening, should it Wayne?
McGizmo: You must be doing the right thing to not experience the shutdown... and you have done quite a few too! I can't understand where I went wrong both in the uninstalled BB750 and the AA potted BB750 in the McModule! I am really at a loss /ubbthreads/images/graemlins/frown.gif. Oh, I am getting 1.8A at the tail with partially used ~90% 123s. Yeah the DB's would be more efficient and less heat would be loss.
Doug: "effect of lengthening this path"... actually Doug, my plan was to provide more area for heat from the chip to transfer to the AA. The top of the IC is only 4mm x 4mm. My copper heatsink adds at least 12-15 times more surface area for heat dissipation. Also the heatsink was put on the diode as well.
Maybe I just have to put this down to a learning experience /ubbthreads/images/graemlins/frown.gif
