Beamshoots of Quark, LiteFlux, NiteCore, ...
HKJ
Copenhagen, Denmark
[size=+3]Beamshoot comparison to 4Sevens Quark AA/123[/size]
For my danish review of Quark AA and Quark 123 I did a comparison with some common AA/CR123 lights and took beamshoots of the lights. I have collected all the beamshoots here.
The lights included are: 4Sevens Quark 123, NiteCore EX10, Fenix P2D, LiteFlux LF3XT, SUreFire Backup, 4Sevens Quark AA, NiteCore D10, Fenix LD10, NiteCore EZ AA, LiteFlux LF5XT, Proton Pro.
The graphic above shows the maximal light output for the different lighs, this is measured with a ceiling bounce.
Next I have combining all the leves in one graph with a log scale, but some lights has a low that is below the minimum scale (Quark AA/123, NiteCore D10/EX10, LiteFlux LF5XT, Proton Pro). For lights with fully adjustable output, only the min and max level is shown, this is NiteCore D10, LiteFlux LF5XT, Proton Pro, NiteCore EX10, LiteFlux LF3XT.
The above graph is a measure of lux at a fixed distance and then scaled to make Quark AA 100%
[size=+2]Max light output[/size]
Quark AA eneloop, Quark AA LiIon, NiteCore D10
Fenix LD10, NiteCore EZ AA eneloop, NiteCore EZ AA LiIon
LiteFLux LF5XT eneloop, LiteFlux LF5XT LiIon, Proton Pro
LiteFlux LF3XT, SureFire Backup
OLight M30 Quad die led
[size=+2]Max light output with reduced exposure[/size]
[size=+2]Min light output[/size]
Lights with a low that does not show on the pictures are excluded from this list.
LiteFLux LF5XT eneloop, LiteFlux LF5XT LiIon, Fenix P2D
SureFire Backup
OLight M30 Quad die lysdiode
[size=+2]Quark AA[/size]
eneloop: moonlight, low, medium
eneloop: high, max
LiIon: max
eneloop moonlight:
eneloop low:
eneloop medium:
eneloop high:
eneloop max:
LiIon max:
[size=+2]NiteCore D10[/size]
The low setting is not shown.
Max:
Max:
[size=+2]Fenix LD10[/size]
Low, medium, high
Turbo
Low
Medium
High
Turbo
[size=+2]NiteCore EZ AA[/size]
See some more beamshoots here: NiteCore EZ AA
eneloop: low, high
LiIon: low, high
eneloop low
eneloop high
LiIon low
LiIon high
[size=+2]LiteFlux LF5XT[/size]
eneloop: low, high
LiIon: low, high
eneloop low
eneloop high
LiIon low
LiIon high
[size=+2]Proton pro[/size]
This light also has a red led.
High
High
[size=+2]Quark 123[/size]
Moonlight, low, medium
High, max
Moonlight:
Low:
Medium:
High:
Max:
[size=+2]NiteCore EX10[/size]
Max:
Max:
[size=+2]Fenix P2D[/size]
Low, medium, high
Turbo
Low
Medium
High
Turbo
[size=+2]LiteFlux LF3XT[/size]
High
High
[size=+2]SureFire Backup[/size]
Low, high
Low
High
thanks for those buddy I will be buying the quark AA it certainly seems like a great edc flashlight :hitit:
HKJ, thanks for such a great comparison of these lights. This is a very useful review. Your bar-graphs are just what I was looking for. I was particularly interested in the new Quarks.
Hugh
Thanks for taking and posting such a bunch of beamshots :twothumbs
PS: i never expected the EZaa beeing such a monster with li-ion
Thanks for your time, HKJ!
Awesome comparison!
Those pictures in lygte-info website are amazing too... Thanks for posting them!
:grin2:
I have done some updating:
A few of the pictures had white balance problems, to fix that I redid all photos with locked daylight white balance (This did not include any picture taking, just another processing of the raw files). It might be necessary to press F5 to update the pictures (Check the Quake 123 and M30 pictures, the grass must be green, not white).
I also added a graph of throw.
Thanks for the beam shots! I wasn't aware you could get more lumens out of the Quark AA with a 14500! Nice!
Why Surefire Backup has so little output? It runs with cr123a...
The E1B is rated for 80 lumens. Some people may get lucky and have ones with 100-120 lumens. There are many other LED lights out there producing 150-200 out the front lumens.
The E1B uses an optic to focus the lumens it does have into a tight and bright hot spot, with some spill. So it looks brighter than a lot of other lights that have more lumens as their lumens are more spread out into a larger hot spot and brighter spill.
mmm
Is there the possibility that i have got an E1B with 100-120 lumens???
How can i do to have it?
mmm
If you had a lightmeter you could compare bounce lux readings with your other lights and sort of figure where your E1B is at, lumen wise. I think that the E1B beam shots at the grass show the beam to be very bright in the center spot compared to most of the other lights.
Bill
HKJ, thank you for all the information. Do you know why the Quark AA is brighter on a Li-Ion battery than the Quark 123? Shouldn't the head be the same in both these lights?
Yes, the head is supposed to be the same, my guess is tolerances on led and driver.
if you get bored with those i will take a donation of all your quarks/fenix/nitecore , nice job
Thanks -- most interesting results.
I've been considering a SF Backup as my next EDC.
Now that I have the AA Quark and see what a quality product it is, I'm not so sure, especially after your tests.
(And looking at your photo of the Backup and the Quark side-by-side, I'm really not sure, since the two are so close in size. I know that the SF has plenty of advantages, but I'm no longer sure I need to spend that kind of money.)
As to the Quark, I didn't know if I'd like the UI. But that was before I tried it. It's as much fun as my favorite pocket carry, the D10R2.
Two wishes:
1) For a tighter clip and one that, like the D10, allows nearly the entire torch to stay hidden inside the pocket.
2) For a clicky that doesn't require quite so much pressure.
Wonder if I could replace the clicky on my standard Quark with that on the forthcoming tactical model.
Or would I have to return the whole light and get the tactical instead?
Any suggestions on either the clip or the clicky?
Thank you for the answer. I just read your detailed Danish review (translated by google) - there are really interesting measurement results there but I don't understand some of them. The current consumption for the high and low modes looks normal to me but something strange happens on medium. The light consumes 130mA - that's less than 180mW on a fresh NiMH battery. The power consumption shouldn't change during the runtime so it should also mean that even an Eneloop would be able to power the light for more than 12 hours. Yet the specification gives only 6 hours in this mode. Could you comment on this? Was there something in the translation that made me misunderstand this result?
Below the current measurements you placed the plots of the voltage as a function of time. Are those oscilloscope measurements of the voltage on a photodiode? Does it mean that the Quarks use the PWM (albeit a high frequency one)?
EIDT: I just noticed that you made also a review of the Quark 123. My questions are related to the Quark AA review.
