hivoltage
Anything new out there, something I can carry in a small holster, high quality and bright and floody?
Quark MiNi. Cheapest, by far smallest, likely the brightest, the best customer support, (probably) the best built, the lightest, the best-looking, the easiest interface, the best beam pattern, the most impressive, the... ok, I've run out.
Get this light. Seriously. Get a set of AW RCRs and an Ultrafire charger and go to town. This is my end-all, be-all light
Joshconsulting makes some pretty big claims! But the Quark Mini is definitely a great little light. I own two and they are both very bright and easy to operate. If I had to find something wrong with it, I'd say that the UI sometimes cycles through the modes quicker than I'd like due to triggering the twisty with pressure while twisting on - but this isn't a deal breaker. If I lost my Minis, I'd buy them again for sure.
To summarise - they're bright, well made, and fairly floody. And cheaper than some other lights out there. Good luck.
Rather than a 123 light, you might consider the Quark AA. You can run it on a 14500 which yields exactly the same output levels as the single 123 torch, but retain the ability to use the ubiquitous alkaline AA in a pinch. The Quark AA is a bit longer than the 123, but I find that an advantage rather than a disadvantage for anything other than pocket carry.
Have you considered the Mac's Customs SST-50 EDC? I don't know if it has enough runtime for you Hivoltage, but I know you like quality.
