Megalamuffin
I have some sofirn 14500 batteries that I use in all my lights that take them. They work fine, but is there any one particular 14500 that's the best? Are there any with a USB port besides the lumintop branded option?
I've had good luck with orbtronic and epoch and have even used them in a series in my lumintop lantern with no problem.
I have a couple of Nitecore NL-147R I've been using regularly for ~6 months in an ET D25A MKII that I use mostly on max for modest durations. They're rated 750mAh - 2A cont. max out (at BJ), have inboard USB charging, and are short (listed 49.5mm (at BJ), so they fit lights w/'short' chambers like the above. My calipers are in storage so I haven't measured them. When new they tested @778 and 773 mAh on Opus 3400 to 2.8V @200mA discharge rate. I haven't re-tested them, but just ordered 2 more of the same because I wanted a couple more and consider them OK so far.
Edit: I can't say they're "best" because I've not used / tested many others.
EDIT-Turns out there is a Keeppower 14500 with get this 1950mah!! Check them out. https://www.illumn.com/batteries-ch...button-top-micro-usb-rechargeable-2-pack.html
I'd recommend Vapcell F12 or H10 they aren't oversized and have excellent capacity. I haven't tried Orbtronic, but they are listed as 55mm long so they may not fit in many devices.Are the Orbtronic 14500 cells mentioned in this thread still the best or at least a good option? I don't need protected cells and don't want on-cell USB-C charging or voltage regulation.
