Best led light for spot
rustynuts
Im wondering what everyones thoughts are on the best hand held LED light would be for spot lighting. Im primarily interseted in distance I guess the further the better as we often fox out to 250 meters. Is there such a beast that would do the job or am I dreaming.
Kind regards
Rusty
Most of the lights with aspherical heads should come close to what you need.
I've got dereelight dbs with aspherical head and R2 pill, in pitch black, 200m is not much of a challenge.
Unless you specifically want an aspherical.....Solarforce Masterpiece Pro 1(+55K lux with UCL), Tiablo A10(50K lux), Jetbeam RRT-1(40K lux), Lumapower VX with Turboforce head(+60K lux). All are good to 250 meters. All around $100-120 dollars. Or you could spend $400 as in the earlier SR90/91 suggestion.
Rusty, put these words on e bay . . . "25 million cp rechargeable portable spotlight with leds"
You'll get 25 million busting loose candles with a 10 inch lens, for $68. :popcorn:
If you're looking for something still pocketable, one choice would be the Surefires with TIR optics - mainly the LX2 or E2DL. They throw very well for their size.
Kind regards
Rusty
No sir your not dreaming like already mentioned the light's like Tiablo and Dereelight DBS V3 can do 250 without much problem at all, just be sure and order the aspherical head for them. I have a Tiablo A9 and Dereelight DBS V3 Q5 with aspherical I have tested them up to 300 meters and they do it well. Both light's with just the regular head and not using aspherical can do 180-200 meters.
Here is a good place to get what you need.
http://flashlightconnection.com/Flashlight-Connection-Home-Page.html
