Tana
Why not try and use M61NLLL (4500K-5000K)???
You can still run in on 2xAA once you're out of CR123's...
This is what I run, in a G3, with 6 123 in a carrier. 3 sets of high energy, high stability cells, with the option to grab pairs of AA wherever - and an engine that will take a huge range of voltage and deliver insane runtime from all of them.
Well, I ordered M61LL some time ago with this setup in mind but it ended up being too greenish for my taste... so I used M61WL instead and I'm very happy with it knowing in case of emergency I can pop in 2xAA and have about the same brightness but long runtime as light outputs slowly decrease... but it's emergency, you're happy with anything above 20 lumens...
There are some great ideas in this thread. I like the idea of a G3 with an M61LLL and the versatility it brings. Are G3s available anywhere, or is it something that would best be found in the marketplace?
Is there much performance difference with running a 2xCR123 spacer and 2 1xCR123 spacers?
Thanks. I'll look into it. If it turns out to be too expensive, I'll probably go the MD3 route.I haven't seen a G3 for sale in quite a while - your best bet will be CPFMP or ebay. As for the performance difference between a two cell or one cell spacer, there is none.
Do you find the 30 or so lumens to be bright enough for most indoor tasks? I'm looking into the emergency bag setup, so I'd want it to do short distances outdoors as well. Since the M61NLLL is sold out, I might go for the LLLL.I have a G3 with 3x CR123s and an M61NLLLL I use around the house. I don't think I will be changing batteries in it for quite some time.
I didn't expect there to be a difference between the 1 cell and 2 cell spacers, but I thought I read here somewhere about the different resistances somehow affecting run time. I could be thinking about something else entirely, though.
Is there really enough difference in runtime to justify a NLLL when the NLL is currently available?
--flatline
