Best rechargable combo for my 9P
KeyGrip
Back in Santa Cruz
As the title suggests. I want to pair a LumensFactory lamp with a rechargable setup, but I am new to the combinations of lamps and cells. Does anybody here have any real world experience with this? What would you recommend?
Leef doesn't do any extenders at present and they would be for 18mm cells anyway. (But 17mm ones would be ok). Surefire do the A19 extender which should be perfect for you.
use 2 x 17500s w/o extender with option to use 3 x cr123 primaries as back up.
Use D26 HO-9 or EO-9 for wow factor.
No need for extenders as 2 x 17500 = 3 x CR123a in length.
Sean
a 1 cell extender, a pair of 17670s, and a SF P91.
I've done this with my 9P, thanks to mdocod's suggestion a while back. It put's out a wall of very white and bright light. Can't go wrong with this setup.
Thanks everbody.
@Mdcod: What kind of output and runtime I could expect from a set up like that?
IMO-
X3
I absolutely love this combination. Pretty impressive runtime, very nearly flat output and extremely bright, white, long, wide throw. Has to be tried if you have all the pieces.
i would go with 2 x 17500 + P91 (or other LA from LF or WE)
beware, if i am not mistaken, P91 (6.6V) is overdriven w/ 2 li ion cells (7.4V)
the light output will be nice and bright, but it might shorten the life of the LA
If you don't mind buying an extender than I would just buy the Leef 2* 18650 body. Then, you get 2200mah (18650) compared to 1400mah (17670). This allows you to get a 45 minute runtime as apposed to a 30 minute runtime. Using 2 * 17670 is just wasting all the extra available capacity (and thereby 15 minutes of extra runtime).:grin2:
Keep in mind that is a ~3C load, li-ion is generally rated for 1.5-2C. I wouldn't *recommend* that configuration per se.
sorry, my bad
you are correct
now that i do the search again and realize 17500 only has 1100mAh (and 18650 has 2200 mAh which is double the capacity)
I use this combination exclusively with the P90 and P91 (but I use mostly 17670's with the A19 extender for the P91 because the 17500's can't handle the current draw as well as the 17670's can) and have never had a problem. The P90 and P91 are both used with three lithium 123's = about 9.6v (fresh cells), so using two 17500's would not overdrive them as the 17500 x 2 voltage would be about 8.4v fully charged. However, the 17500's/17670's have a flatter discharge curve than the lithium 123's (not as much voltage sag under load), which gives kind of a semi-regulated effect, causing the P90 or P91 to stay whiter longer than on lithium 123's. I don't notice much dimming until maybe about 5-7 minutes before the cells shut off.
Extra runtime is always good, but which LA would I use with the 18650s? P91? HO-9? Thanks for your time, guys. I'm totally new to the world of rechargables, so this is a lot of learning for me.
If one doesn't care as much about reliability, 18650's are the way to go. For my often used lights though I like to stick with 17500's because the voltage drop across the lamp is similiar to CR123's. I think 18650's into even.. say 2A is going to be driving the lamp quite a bit more than spec.
For my more serious (mission critical) lights I really like the HO-9 on two 17500's.
Just stick with the P90. It begs to be powered by 2 17500's and will give you near regulated output for close to an hour. You haven't added any additional length or weight to the light and output is significantly "whiter".
I have the LF lamps that others mention and they are strong performers too. They provide slightly more throw at the cost of spill. But the P90 is superb for providing a peripheral view and in my opinion is a whole new lamp on Li-ion. You should at least try it.
Of course, I have the H09 and E09 at the ready in other lights.:thumbsup:
The P90 and P91 are both used with three lithium 123's = about 9.6v (fresh cells), so using two 17500's would not overdrive them as the 17500 x 2 voltage would be about 8.4v fully charged. However, the 17500's/17670's have a flatter discharge curve than the lithium 123's (not as much voltage sag under load), which gives kind of a semi-regulated effect, causing the P90 or P91 to stay whiter longer than on lithium 123's. I don't notice much dimming until maybe about 5-7 minutes before the cells shut off.-socom1970
there seems to be some confusion about li-ion giving regulated effect, and some confusion about the difference between li-ion and lithium primary configurations as it pertains to the "overdrive effect."
For the sake of explanation, I'll use a P90 and P91, 2x17500 vs 3xCR123.
CR123s, into the load of a P90, don't spend any longer than a fraction of a second maintaining 3.2V per cell (though they often do measure 3.2V per cell OPEN-CIRCUIT). Within the first second, they drop to about 2.75V per cell, and then level off at about 2.5V per cell after within a short moment. A CR123, will then continue delivering very near 2.5V for about the first 30 minutes, only dropping to about 2.4V at around the 30 minute mark. At which point it starts to gradually decline to around the 2.15V mark before suddenly falling off the map.
So.... what does this do for output? Well, lets assume that the first few "moments" don't count for anything besides an expensive thrill, so the "starting point" that we'll call 100% output is occurring with 7.5V worth of cell voltage available. After 30 minutes, output drops to 87%, not bad, at the ~60 minute mark it drops to about 60% output, then somewhere around that point it "falls off the map" (goes totally dim and useless within a few moments). So we go from about 100% down to around 60% output before the batteries are about to "die." That's not too bad.
Lets compare that to a pair of 17500s on the P90...
A 17500 does come off a charger at 4.2V, but like the primary cell, this is an open-circuit-ONLY voltage. Under the load of a P90, a 17500 cell immediately sags to ~4.0V and begins a relatively steady decline in voltage through the length of the run. In the first ~30 minutes or so, they drop to about 3.7V per cell, then over the next ~30 minutes (just before "falling off the map") they drop to about 3.45V each. So we actually start off quite a bit higher than the CR123s, at about 124% of the primary configurations output to start with, declining steadily to about 95% of the primary configurations initial output in the first 30 minutes or so, then declining to about 75% of the primaries initial brightness at about the 1 hour mark (give or take a few minutes depending on cell brand).
In comparing these 2 situations, we see that the lithium-ion actually runs brighter for the majority of the run. But this can vary depending on what brands of cells are compared. BOTH configurations drop to about 60% of their initial level just before the cells "die." So lithium-ion really isn't all that much flatter than a primary configuration... But, keep in mind, that the initial "spike" on CR123s (of around 2.75V per cell OR HIGHER in some cases) is actually probably as hard, or harder on the bulb as running with a more controlled overdrive on li-ion cells. (the li-ion would rarely if ever hold above 8.1V in this configuration at the cell, where CR123s could theoretically deliver 8.3+V at the cells for a short moment before they settle down)...
Now.... When dealing with the P91, we are getting into some serious power. 2.5A has been reported on 3xCR123 configs, and 2.7A is routinely reported on 2xli-ion configs (I can verify this through personal experience)... this fact alone tells us that there is some substantial overdrive going on with li-ion cells in play.... but we can simply refer to the charts for further enlightenment (Silverfoxes battery charts)...
Interesting thing when you get into loads like this, CR123s really don't have a chance, literally half of their available power is wasted as heat, they start off into 2.5A at about 2.2V and drop to somewhere around 1.6V in about 20 minutes. So, assuming a P91 starts at "100%" at 6.6V on primaries, it drops to something like 40% output around the 20 minute mark, then falls on it's face.... but keep in mind here, that at these loads, there are HUGE variations in performance from brand to brand, and the discharge characteristics will even vary heavily from cell to cell quite dramatically as well. It's really a great way to flush CR123s down the toilet, lol. Sorry kinda getting off on a tangent here... but moving to a 4xCR123 configuration can actually deliver very similar lumens, but for a full hour as opposed to only 20 minutes. (because "12V" style lamps have filament designs that happen to tend to be more efficient, and you can drop down to a lower current, at which point the cells hold their voltage better)
Anyways... take the same P91 on 2x17500 and you actually start off around 3.75V (or higher) into the load per cell, dropping to around 3.2V per cell before falling on it's face. So on 17500s a P91 actually starts off at about 150+% of the initial brightness on primaries, and actually ends up at about 90% of the primaries initial brightness at about the 20 minute mark. Which is totally awesome, this does shorten bulb life. And there is still a substantial decline in output through the run, but in this case, it's much better than primaries.
