357mag1
357mag1 did you get my pm?
Just got it. I didn't notice PMs piling up in my inbox. Thanks for the heads up.
CyberCT,
Current in series is common so whatever current is at the tailcap all cells are felling that draw. In the case of the TK70 all three cells are feeling the 9.84amp draw (from my test). With 4 cells it drops to 6.25amps and again each cell has that current drawn through it.
My Newer TK70 draws 10.7amps on 3 cells and 7.2amps with 4 cells.
You know, I'm thinking about the LION option. If the TK70 steps down from turbo to high when only 3.8v is available from the batteries, wouldn't a LION step down too soon? If you charge 2 LION 32600 cells to say 4.2v and then use them in the TK70 the TK70 would step down when the LIONs are only what, 70% capacity remaining? Because LION cells are rated at 3.7v.
Did a runtime test of 4 of 8 Tenergys fresh off "soft" "condition" mode from my Maha 808S charger. 1 hour 2 minutes till the light stepped down from turbo to high. You can hear the driver in the light at the end squealing. It sounded like a dive bomb and then went silent haha.
Of the other 4 that were finishing the "soft" "conditioning" mode, 1 battery ended with the other 4 that went into the TK70, but 3 just kept on taking charge from the charger, blinking with the 3 capacitiy indicators on full. After over an hour and a half of continuous blinking, after the last of the other 5 batteries finished, I just took them off the charger. Is that OK? My assumption was that these 3 are crap cells and the charger is having a difficult time distinguishing their final capacity which is why the charger keeps trying to feed them charge till done.
I tested the TK70 in the tub in cool water. The head and heatsink were just a tad warm even under the cool water at 1 hour 2 minutes. But not hot at all.
357mag1, please help me understand. So two LION cells at full charge each are 4.2v x 2 = 8.4v. So nominal LION cell voltage is 3.7v x 2 = 7.4v. If each cell was discharged to 3v each (the safe minimum), that's 3v x 2 = 6v. With no battery protection, the TK70 driver would not step down from turbo to high until just 3.8v was available. So it would drain the LION cells down to 1.9v each x 2 = 3.8v.
Actually they were probably your better quality cells as far as capacity is concerned. The first one off conditioning on my Maha 808 is the cell that tested lowest in capacity. The cells that could go over 8000mah took much longer. The reason for this is they take longer to charge and discharge. So contrary to what you thought those are probably your highest capacity cells.
I think you are correct. That second batch of batteries, the 3 that I took off the charger charging 1.5 hours longer, 1 that finished previously with the rest, lasted 1 hour 10 minutes on turbo in my light. That's pretty darn good! I thought I read somewhere that the TK50 battery tube fits on the TK70 tube. I'll have to confirm it but if so and I can find a distributor that sells the tube only then I'll spring for it. If I can get more runtime with the light and with less squealing at the end of turbo mode (which would scare the fish away maybe?) then I think that's ideal.
The AccuEvolution cells which test out between 8500 -8900mah struggle to reach 60 minutes. That higher voltage under load makes a difference, the TK70 on Turbo draws over 1amp more from the AccuEvolution cells due to voltage sag which depletes the cell quicker.
I just tried it and the TK50 battery tube fits. I added the spacer and used 3 D cells to make sure it made proper electrical contact and it does. The TK70 spacer doesn't seat into the TK50 tube deep enough for the O-ring to seal. This applies to the TK70 tailcap as well. The O-ring is still exposed when it is screwed down tight on the TK50 tube. You would need a TK50 tailcap as well or someone to modify the TK70 cap length to fit. Problem is once modified the TK70 tailcap wouldn't make contact on the TK70 tubes.
I'm assuming you intend to use Lithium-Ion cells. Remember two of them are about .8inches longer than two Nimh D cells. You have about an inch of spring to work with in the TK50 tailcap so it could be done. It would be an unbalanced light though, very head heavy and tend to want to tip toward the head unless you placed your hand around the switches.
Not trying to dampen your enthusiasm just bringing to light any potential issues I can foresee. You might as well buy the TK50 outright, it is a great little light.
On conditioning -- I have a Maha C9000 (the AA-size charger).
It has a 2.0A power supply.
I can extend the contacts with clips and wires and magnets to handle these Tenergy D cells.
How do I set it up to condition/break in these cells -- how many can it handle at what charge/discharge settings?
Although they have not arrived in the mail yet, I bought a set of those AAA to AA adapters. I bought a wooden dowel at Home Depot for $1. I will solder 20 gage solid copper wire (plastic sheath like all wire, but the copper is not braided) to the inside postiive and negative ends of the AAA AA adapters. Then I will cut the wooden dowel down to the size of an AAA battery and put it in the adapters to keep tension on soldered ends from being yanked out. I also bought those 2D cell series adapters in Radioshack for $2 each. I will wire them up as individual cells to each AAA AA adapter to put in the C9000.
Sounds good; I was thinking of using alligator clips but the plastic-adapter-and-dowel sounds like a better electrical contact.
I'll get the same stuff and follow along behind. Do you have a notion if you can condition more than one of these D cells at a time, given the 2.0A power supply?
My only plan for using the C9000 with my D cells was to do a discharge at 1 amp per cell. 1 amp is the max discharge rate the C9000 will allow. Since I'm essentially discharging batteries wouldn't that use very little power from the outlet? I didn't know the power supply draws a max of 2amps from the outlet. That doesn't make sense though because if you just charge four AA batteries at 1 amp each, that's 4 amps.
This is a super deal and super hard to pass up.. he has 81 of them left (show 81 sets of 8)... He also has another auction with 4 for 15.00 in case you dont need 8
Also posting in the good deals section
http://www.ebay.com/itm/360432953035?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
If this isnt allowed I apologize in advance and please remove the link
I've done OK with those blue ones from that vendor. Out of the plastic they are really low at .87 to .94, mine have charged up so far. I'm putting them in my lanterns, mag lites and my tent fan. It sure helps the wallet at half the price of my Tenergy Premiums. :thumbsup:
