I'm currently making a 5x sscp7, 2x cree r4, out of some .1" aluminum and sheet steel. My middle school doesn't have tig so I'm going to braze it, is that material farily heat conductive. I would like to add a few heat pipes behind the plate that holds the leds and was thinking of using some fiberglass as a wick. Would that work? Also, What would be the best way to get the heatsinks to make good contact with the aluminum plate? It seems soldering doesn't work, I tried it. I'm also making a tempature based fan controller circuit so that it has enogh heatsinks when it is not moving
These are all the parts for the flashlight. Its alot of heatsinking, but I might add some more leds.
This is the heatsink plate, this is where I won't to attach the heatpipe to.
