Coop
I recently bought a recumbent bike (Challenge Hurricane Sport USS) which came equipped with a SON hub dynamo. I'd like to make a nice light for this bike and have a few ideas, but some advice is always welcome.
First of all, I'd like the light to be fairly small, as on my recumbent it will be mounted on the part that would be called the bottom bracket on a regular bike, so it is in between the cranks.
Now one of the ideas I had was to use a flashlight bezel that is compatible with the P60 style lamp assemblies, so I'd have a choice of dozens of different LAs to choose from and upgrading will be easy as I'd just have to replace the LA as better versions come out.
Then have one of the modders here on the forum make me a sort of screw in plug that screws directly into the bezel to keep the LA in place. Mounting could be done by screwing a bracket between the bezel and endcap.
I was planning on using a good LED drop in like the Malkoff or the Wolf Eyes that I already have. But of course I can't just hook these up to the SON directly.
I could hook it up using a bridge rectifier and a voltage limiter, but I was thinking about powering it from a Li-ion cell/pack and have the SON charge that cell/pack. This would have a few advantages. First of all, the light will stay on when I stop the bike, which is a big plus on the safety side. Another advantage would be that I can switch off the charging circuit, reducing drag on the hub and still be able to use my light. I'd like to have the option to power the light from the hub too for when the battery dies. Another option I've been thinking about is using the DX drop in with wide voltage range (http://www.dealextreme.com/details.dx/sku.6090) with just a bridge rectifier between it and the SON, it would make a nice temp solution until I get the rest of the system figured out.
So what do I need help with?
- Who can make me the mentioned endcap and how much would it cost?
- What do I need to make a Li-ion cell/pack charge from my SON hub?
- Am I overlooking anything?
