Hi all,
The Olight M2R and M2T have a side switch and a tail switch, which can both be used to turn on/off the light: the tail switch for a tactical use of the light (instant access to Turbo and Strobe) and the side switch to access lower modes.
Do you know any other lights which can be turned on using either switch?
Many lights (e.g. Fenix, Nitecore) have a side switch which can be used - to change modes - only once the light has been turned on using the tail switch.
Wishlist: 18650 size, neutral white LED preferred, and instant access to turbo and strobe using the tactical tail switch.
Another option would be only a tail switch, that allow to access either the tactical Turbo and Strobe modes, and any other less bright mode. Are there any lights with such an UI, or a double switch in the tail?
