woodrow
Hey everyone,
I just received Brightstar's Lighthawk Led Lantern from the nice folks at Brightguy. (they are a great company to buy from...great customer service...and fast shipping with a tracking #) The lighthawk lantern has been out for a while now in xenon, but the led version is what I was waiting for.
First, it comes in a nice box with instructions for use. They are general instructions, for the 4, & 6 cell incan versions, but they include a spec card for the led version.
First, as the name implies, it is LIGHT!!! It only weighs 1.9 pounds...batteries and all. Secondly, I like that it uses Lithium batteries (4 I am guessing) so it will not have the nimh discharge rate or the nicad memory effects. The light has a swivel head that really stays put unless you move it.
It also has alternating red and white flashing leds on the back that are controlled with the main (only) switch. Simply move the switch forward to turn the main beam on without the rear leds flashing. Move the switch to the middle position to turn all lights off. Move the switch to the rear position to activate the main beam and the rear (pretty freakin bright) strobing led locator/warning leds.
I can see how the locating flashers would be great for a fireman in a smoke filled house to be easily followed by his buddies, but I also see uses for the rest of us when using the light to walk down a busy road, or using the light to change a tire.
The light is 10" long, 3" wide (body), 3&1/2" at the bezel, and 5" tall. You seriously cannot believe how light this thing is when you pick it up. It just feels like something you could carry for hours without being bothered by it.
Ok, now for the important issues. First, it it BRIGHT! It is rated at 100 lumans by Brightstar, but either they are underestimating their output #'s or, my other lights are over estimating theirs. (both are most likely true.) I do not know (and brightstar does not say in the instructions or anywhere else) what kind of led it has in it, but here is a picture. Maybe you all will be able to tell.
The led produces a very white, not purpleish beam and the beam looks like that of a Ultrafire C2 or Streamlight Propoly light. It has a bright center spot, with the hugest spillbeam of any of my led lights. Even bigger than the C2's wide beam. It has great reach as well. I think the Pelican 7060 is a little bit brighter overall, and it has a bigger spot and brighter spill, but the Lighthawk's spill is twice as wide as the 7060's. This makes it nice for walking in a cluttered area, or outside, because the spill is right in front of your feet. Not out ahead of you 5 or so feet like the 7060 or D-mini.
Overall, I really like the light. This is the light I wish the Streamlight SurvivorLED should have been. (and I bought 2 of them) It is about twice as bright as the Survivor and not much heavier. It will run for longer and uses lithium batts not nimh's. It is at least as bright as my C2 and D-mini Cree lights and almost as bright as the 7060 which has been rated up to 175 lumans. Plus, it will run (manufactures #'s) for 7 hours on a charge and gives you a low battery warning about half an hour before shutdown. It at $173.00 is not a cheap light, but worth every penny in my opinion. This light is impressive for the average flashlightaholic and it will be impressive for professionals who must trust their lives to it as part of their equipment. Seriously, check one out. I think you will like it. I will post beamshots shortly.
Thanks for taking the time to read this.
