I installed a warm module in a 2C mag that I modded to 3 123A
Pics on the mod?
Well , I installed a warm module in a 2C mag that I modded to 3 123A and
I'll have to say that the amount of OTF light , coupled with the form factor , make this a serious contender in the ' sleeper light ' category .
:naughty:
They fit great though the spring is too long ... I just squeezed the spring with pliers till it was short enough to fit nicely ... Only snag now is that two C cells don't fit properly unless I use magnets.You'd probably fit two 18500's in there quite nicely too.
I can only say what I did when using two protected 18500's in my 2C Maglite ... To avoid too much pressure on the PCB's I chose to squeeze the spring down a bit in length ... If you want to risk using perhaps too much spring pressure on the PCB's or if your 18500's are unprotected (shorter) then it's up to the user to decide ... I was being cautious ... It does work very well though.18500's should be the same length as AA's and C's.
I'm using Trustfire (silver/grey) 18500's ... Their length is 52.60mm and my Duracell Procell C's are 49.27mm long.Fair enough. What brand are you using? I know some are a bit longer than others, by as buch as a few millimetres.
I have to say that since the XM-L emitter has come about in P60 format, my Fusion 36 has been gathering serious dust!
Good to hear he backs up his product.I am thinking about ordering a 2nd one.I sent my dead-on-arrival Fusion drop-in back to the seller and they fixed it and sent it back with epedited shipping--took less than a week to get back, and now it works like a champ. So not only is the drop-in great, but so is the seller!
