sosemot728
I'm going to have a crack at designing and making a flashlight. So far I have decided on.
LED: Single XP-G R5
Material: Aluminium 7075 with Stainless Steel front and rear Bezel's (Also a Titanium special edition)
Lens: UCL
Switch position: Rear Clicky
Modes: Off, On (High) and On (Low) with mode memory.
I want to try something different and have a two piece light; i.e. no center thread joint, I have a few different ideas on how to do this successfully.
I need help deciding on the following
Reflector: ???
Maybe the Ledil Regina?http://www.ledil.com/datasheets/DataSheet_Regina.pdf
Battery Type: ???
I cant decide between 18650 or a single CR123A.
Driver/Regulator: ???
Must be able to drive 1.2~1.5A at a high efficiency.
Switch type: ???
I need a reliable source.
So... Any preferences or suggestions?
LED: Single XP-G R5
Lens: UCL
Reflector: ???
Battery Type: ???
Switch type: ???
