Machining the Gen. 2 Body
Oh boy was this ever a lot of work! I
started machining
5 bodies and
finished with
2 usable ones. Let it never be said that owning a lathe makes things cheap. Time, materials and sanity are all resources with a cost. :duh2:
We start (as we always do) with a chunk of metal. This time there's a lot hanging out of the chuck!
I was feeling wild & crazy for this workpiece so decided to break out the Steel Blue. It's a quick-drying metal dye (also called a layout fluid) that forms an ultra-thin layer that you can scratch to mark your workpiece. It shipped in 3 nested Ziploc bags with a large warning sticker on each and displays warnings on the front, top, and bottom of the bottle. My machine shop instructor only ever said one thing about it: "Love that smell but I guess it gives you cancer or something".
If you buy a half-decent set of calipers, the majority of the body will be made of steel but the tips will be made of carbide (a hard-wearing ceramic). This lets you use them to lightly scratch marks in things... like layout fluid!
Using the scratch lines as start/end points, I cut a little pocket in the middle of the bar stock. The blue dye looks quite striking against the bronze - I wish there was a way to incorporate that into the finished light.
The pocket is
just wide enough to slip the toolholder into so that I can cut out the remaining body material.
After taking a few passes, the mid-section of the light is looking much slimmer. This drops a lot of weight so that the end result doesn't pull your pants down.
Time for my least-favorite operation of all! *bites nails*
They might look ok at first glance but there's actually quite a lot wrong with these knurls. Just between you and me, after knurling the 5th body I was damn near ready to quit out of frustration. Bronze is exceedingly flaky and my knurling scissors have been abused so much that they're no longer sharp. Those two factors resulted in a lot of really poor looking knurls. I'm 95% of the way to convincing myself to drop the big cash (and I do mean big: at $1200+ they're not an impulse buy) and pick up some cut knurlers. Those beauties are used by the likes of wquiles and Fred Pilon to create the nice diamonds you always see on their custom titanium pieces. Instead of simply smashing the metal together they actually cut it away, which means soft metals like bronze are no problem. We'll see.
The next picture showcases a few different operations: shaving down the knurls, adding the 45° bevels to each side, and cutting the form for the tail. You can start to see the body shape now.
Our little guy gets up at 05:45, I work 8-10 hours, spend 3 hours putting him back to bed and
then it's out to the garage. I'm pretty good about recognizing when I'm too tired to be running the lathe but occasionally I'll slip up and do things like bump my finger against the chuck jaws while they're spinning at 1100 RPM.
The tailcap end gets threaded 11/16-20. The same pitch as a McClicky switch. Coincidence? :thinking:
One of the core tenets of machining is "keep your tool lengths as short as possible to reduce vibration and prevent chattering". I don't think letting my tiny boring hang out 2.5" would pass with any kind of approval from any half-sane machinist. A good choice would have been a properly sized drill followed by a properly sized reamer. But... this is what I had on hand so... let 'er rip!
Someone once told me if you absolutely must make a high vibration cut, you can press a block of wood against your cutting tool to dampen vibration. So I did that with my ridiculous boring bar and it worked, leaving a nice smooth finish all the way down the bore.
But does it fit a battery?
Not much more can be done at this point except part off the workpiece. The head end isn't nearly as pretty as the tail.
In between frustrated knurling sessions I tidied up the workshop a bit. Here's where all the magic happens folks. :twothumbs
Once the body was parted off I was left with the fundamental issue of how to clean up the other end. It obviously needed to be re-mounted in the chuck, but with the middle section gone it would no longer fit in the jaws. The solution was to create a soft Delrin collet. The collet would carefully cradle the workpiece while greatly enlarging the diameter, giving the jaws something to hold onto.
Perfect! Nice and soft with a large diameter to grab on to!
My lathe has 2 sets of chucks: a 3-jaw and a 4-jaw. The 3-jaw chuck is kind of a 'cheater' chuck because you just stick the medal in it and tighten down and all the jaws move simultaneously. The problem with the 3-jaw chuck on an import lathe like mine is that it doesn't spin perfectly true. This is called 'runout' and you can see it as a slight wobble in the metal. It's no big deal if your workpiece spends its entire life chucked up - everything spins around one axis and turns out fine. It IS a problem if you ever remove your workpiece and try to put it back in. Now your partially-finished workpiece is wobbling and your cuts aren't true. In a 4-jaw chuck, each jaw is tightened individually. This gives you fine control over the workpiece but it's a pain in the rear getting things dialed in. For our workpiece, the 4-jaw chuck is now necessary so I pull the old one off to put the new one on.
Here's the workpiece sitting in the 4 jaws. You can see how the 2 slits in the collet fit nicely between the jaws allowing an even grip.
We need to get this thing perfectly center before we work on it. This little tool is called a dial indicator. Wobble in the workpiece causes the hand on the face to move. It's then a matter of tightening the jaws until the wobble disappears.
After 4-5 minutes of adjustments, things are looking pretty darn good!
If it weren't centered properly you would see it here in the wall thickness - one side would be thick and the other thin. Not something we want!
We're working in such a tight space that my standard threading tool won't even fit without destroying things. Since the threads aren't very deep I can switch to this tiny little threading tool bought specifically for this task.
Hey that looks pretty good! The ledge at the bottom gives the head something to tighten down onto for a nice, positive feel.
Of course we need to make sure the driver pill actually threads in there.
There are sharp edges
galore so we start adding countersinks and bevels all over the place. Can't have any sliced fingers or nicked batteries!
Almost done! The knurls are full of flakes and the threads full of swarf so its into the soap bath for this workpiece.
You know, I think this'll work.
I'm still waiting on o-rings and switch boots (c'mon FastTech, hurry up!) so no final assembly shots until those get here. At that point I'll know whether all the joints are waterproof and the machining correct. That's ok though, gives me some time to flash the drivers and make sure I'm happy with the firmware. You guys'll stop back to see everything put together, right? :devil:
Return to root post
Continue to next post in the series
