Building first ROP... need help
mrmike
Allentown, PA
Sorry guys if this is a dumb question (but I can't find the answer searching through the forums).
I have a Mag 4-D Host, borofloat lens, fivemega MOP reflector, stick of 6 4500mAh sub-Cs from Cheap Battery Packs, (and the bulb of course).
The tailcap spring is wider than the neg terminal end on the stick of cells. Do I need to replace the spring? I see removing the spring doesn't work as the stick of cells just slides up and down in the body... what am I doing wrong?
thanks for your help
