R11GS
What are good bulb options for D-cell mags?
But more so, I prowled around the incan section of the board. And I understand things better. There are probably some drop-in bulb options, but I doubt I'll get very far that way. For giggles, I put a 3cell bulb into the 4D unit. And that was pretty nice. Good and white and nice throw for the twenty minutes or so that the bulb lasted (I didn't expect it to last long). As good as the 6P, but side by side it really makes you appreciate what the SF beams are all about; so smooth and useful.
I do understand now that minimally to make a mag much better than stock, I will have to look into not just bulbs, but most likely a bulb adapter and reflector. Battery change would be a strong consideration. I've worked with batteries for years and understand that with alkaline primaries, the bigger cells (D vs. AA) don't give you more current (power); at least not much - just longer run times. So throwing more AA's can give you more power simply because they'll do the same current as the D's and you can get some more voltage because of more cells. I figure you can safely draw up to about 1Amp from D's or AA's; give or take. So 4 cells will get me around 5Watts of useful. With eight or ten AA's I can get maybe 10-12Watts.
I might consider secondary (rechargeable) Lithiums, but for the toss in the car use it seems any kind of primary is better since they won't see a charger frequently and the unit won't get used a lot. It does not have to have reliability at the top of the list - I always have other lights.
Heck, maybe I'll just get a SF M4 or M6 and throw the 6P in the car!
