bcwang
So I got my new 0G0IA C9000 charger and have been playing with it. I actually have two to test with and both exhibit the same behavior. I started noticing that all my cells tested with very low capacity values. It would have been too much a coincidence that all my cells went bad.
all tests at 1amp discharge rate
tenergy 2500 - 1500-1600 mah
kodak 2500 - 1800-2000 mah
powerex 2500 - 2100-2200 mah
quest 1600 - 1000 mah
eneloop fresh out of package - 1200-1300 mah
I retested some of the cells at 500mah discharge and results were the same.
I watched carefully and note that the discharge terminates when the cells drop below .9 volts. This would be right but then I wonder if the voltage readings are even accurate. Frequently, slot1 will show .97v or around there while discharging at the same time the other slots are showing 1.15v. However, at the end all slots discharge to about the same level as I can swap the batteries around after discharge, and they all end within a minute of insertion.
Now why do I think the discharge isn't going to a low enough level? Well for one, these cells all tested near capacity in my bc900. Using the C9000 results in a much lower capacity reading. Secondly, after discharging the eneloop cells with the C9000, I proceeded to charge them up again at 1amp. When the 4 cells finished, the charger had inputted around 1800mah into all 4 cells.
Other C9000 owners, do you see the same thing? This is my first experience with 0G series units, my previous 0F units were much much closer to the bc900 in results.
