can a fenix l2d q5 be modified to use CR123
exodus125
Miami, FL
comparing the L2d Q5 with the PD30 Q5, the pd30 has 220 lumens on turbo mode where the L2D has 180. Could the L2D be modded to take 2 CR123 batteries to have the same lumen output?
You would have to replace the circuit, and get a new battery tube and tailcap. Replacing the circuit eliminates that famous Fenix efficiency, so why not just get the P3D to begin with?
BTW, the L2D Q5 can run a single CR123. In fact, that's exactly what the P2D is, it used the same head.
i didn't get the p3D because I wanted the L2D, I was just wondering if it was possible.
I guess you could get a p3d head and swap it out when you wanted to.
