LuxLuthor said:
HC, I figured that was the idea...what you and BFG said. However, if lightmad is in the relative noob category like me, trying to figure out what in the world you mean by "15 ohm 1/8 or better 1/4 watt resistor across the leads" is like 1,000 times over our heads in techno-speak.
Just to give you an idea of the level of many flashlight users...I have never used a resistor (consciously) in my life for anything, and am guessing that ohm must be a term used for resistance, and think about watts in terms of 75 or 100 watt light bulbs.
I know everyone means well when they give advice, but I really believe there are a lot of CPF'ers who are starting out from ZERO knowledge about electronics, batteries, charging when they join here.
I NEVER had any understanding about the many differences betwen NiCad, NiMH, Lithium, Lead Acid batteries...or how to properly care for them, life spans, dangers, etc. etc. A battery was a battery. When the D cells in my old flashlights wore out, you throw them away and get new ones. At some point alkaline batteries came out....but all that meant to me was they lasted longer than non-alkaline.
If something like my Laptop or Cell phone came with a battery charger...well I pretty much always kept it plugged into the charger when not taking it on the move. I had no idea that constant/overcharging frequency of many batteries damaged it....nor that Lithium rechargeables lasted about 3 years and then started crapping out no matter what you did.
It was not until I bought my Hyperion charger because Mad Maxabeam told me to get it for charging the Larry14K 28.8V spotlight that I began to pay proper attention to finding out the details. It honestly started when I was trying to figure out what this "LBA10 balance charger accessory" was all about, and if I should be using it while charing the NiMH in the Larry14K. Recently, I just graduated to making some custom tap leads for a FiveMega Li-Ion pack.....I was so proud of my progress.
I say this just so you know that is how "stupid"....or....ummm....rather...."uneducated" many of us are about all these topics....just so you remember back to when you were starting out. LOL!
Oh, and back to your resistor deal....who/what/when/where/how does that get setup with a DMM? I assume you have to get a whole set of various resistors for all the various battery types & sizes....that seems a bit overwhelming to consider....let alone trying to figure out which should go with which battery.
Lex,
Sorry again for the terseness of the reply.
First, the easiest solution is to get a dedicated battery tester scuh as the ZTS. Another alternative is a multimeter with a battery test function (which basically has the simple resistive load scheme I'm describing here built in to it).
The basic problem we're trying to solve is that for many many kinds of batteries (including just about everything in the AAA/AA/C/D form factor), the open circuit voltage doesn't tell you very much about how much energy is left in the cell. By "open circuit", I mean the voltage read when the battery isn't actually in use, e.g., when you take the cell out and just measure the voltage at the + and - terminals. All but the very deadest NiMH cells will read about 1.25 - 1.35 volts, regardless of how charged it actually is. An alkaline cell will similarly read about 1.5 volts under these conditions.
In other words, you can't distinguish between a good NiMH battery and an almost-dead battery just by measuring the voltage across its terminals.
But if you measure the voltage WHILE THE BATTERY IS ACTUALLY BEING USED, it will be lower than that, and the more exhausted the battery gets the more the voltage will drop compared with when you measure it when it isn't in use. For alkaline cells, this voltage drop may be considerable; for NiMH, it will be smaller but still quite measureable.
So you learn much more about the state of a battery by measuring it's voltage while "under load". You can use a resistor (one of the simplest of electronic components) as a load for this purpose.
Now, we'll need to get slightly technical for a few paragraphs. If you understand what follows, you'll go a long way toward understanding basic DC electricity theory and practice, so please bear with me...
You already know about voltage, more properly called "potential" in electronics-speak. It's measured in, well, Volts. A car battery supplies about 12.8 Volts. A rechargable NiMH or NiCad AA battery supplies about 1.2 Volts. Standard residential house wiring (in North America) supplies about 120 Volts (although there are also higher voltages used for certain fixed appliances like heaters and washing machines). Batteries supply "Direct Current" (DC); commercial power is "Alternating Current" (AC), which reverses polarity 60 times per second (in the US). AC is a bit more complicated to analyze and measure, but the basics here still apply. voltages over about 48V are considered a shock hazard and require special precautions. Lower voltages can still be a fire or spark danger if there's a short. So always be careful when working around electricity of any voltage, especially from higher energy sources (like car batteries or commercial power).
Resistance is measured in Ohms. The more resistance something has, the less current flows through it at a given voltage. A short piece of copper wire has a resistance of close to 0 ohms; a dry piece of plastic has a resistance of close to infinite ohms. "Resistors" are the electronic components that provide the values in between...
Any electronic circuit looks to the battery like a resistor of some value. (It's not actually that simple, because many circuits involving certain kinds of electronic components, including light bulbs, have a resistance that depends on the voltage, but for our purposes, any circuit can be thought of as a fixed-value resistor). For most of the circuits you'd use with AA batteries, the overall circuit resistance is between about 2 and about 2000 ohms or more. A flashlight will be closer to 2 ohms; a pocket calculator will be closer to 2000.
The amount of current flowing through a circuit depends on the voltage being supplied to it and the resistance of the circuit itself. Current is the measured in Ampres (or Amps). The number of Amps in a circuit can be calculated by dividing the voltage (in Volts) by the resistance of the circuit (in ohms). So a 48 ohm circuit with a 12V battery will have a current flowing through it of 0.25 Amps, (usually written as 250 milliAmps, or 250mA).
Now you're equipped to understand how battery capacity is measured: in mA/h, or milliAmp-hours. A 2000 mAh battery can theoretically supply 1 milliAmp for 2000 hours or 2000 milliAmps (2 Amps) for 1 hour or 500mA for 2 hours, before it goes dead and has to be recharged. (In reality, it's not quite as simple: there are some non-linearities and inefficiencies at the extremes, but for the purposes of this discussion, that's the idea).
So you'll want to measure the voltage of your cell with a resistor across its + and - terminals. A load of about 15 Ohms will draw about 80mA from a single 1.2V AA NiMH cell. (How long would you expect to be able to do this from a fully-charged 2400mAh cell?)
So, assuming you want to measure single AA NiMH cells: Go to Radio Shack (or whatever your local electronics chain is called) and get yourself a roughly 15 Ohm resistor. The exact value doesn't matter; anything more than 10 Ohms and less than 30 or 40 Ohms will do. (The larger the resistor, the SMALLER the load it will be placing on your battery when you test). You'll need one rated for at least 1/8 Watts (voltage*amps), but that's not a problem because 1/8 Watt resistors are the smalest you're likely to find at any electronics store.
Now you'll need to find a way to have the resistor be across the + and - terminals of you battery at the same time as your meter's leads are across the + and - terminals (that is, you want to measure the resistor in PARALLEL with the battery). The easiest way to do this might be to get a battery holder and solder the resistor across the terminals, or if you're highly dexterous you may be able to just hold everything together with your hands.
Finally, you need to test some batteries to get an idea for what values to expect with your resistor. Test at least three: one right off the charger, one that's been used for a little while, and one that's completely dead, and note the values. That's all there is to it!.
This won't be as accurate as a proper tester, but it will be sufficient for many purposes, and certainly better than measuring without any load at all.
H. Caul
