Cavelightchris
- Joined
- Dec 5, 2007
- Messages
- 69
I was wondering what all you need to run a high power LED like the XR-E 7090 Q5?
Does anyone know of any high power LED's(150+ lumens) that can be wired directly to a battery and work reliably?
I wanted to use as few as possible components possible to make my light I am designing, because I want it to be reliable as possible, less working parts usually does this, so I wanted as few as possible.
Can you series / parallel wire up batteries?
I was thinking this, make two sets of: 5 AA batteries in series to get 7.5 volts, then wire both of them in parallel to get 3.75 volts.
If you can wire batteries in parallel, does it cause your setup to drain more power than if you had wired them in series? Cause this article was saying wiring chips up in parallel drains drains power faster:
"wiring in parallel drains your power supply faster than wiring things in series because they end up drawing more current from the power supply. It also only works if all the LEDs you are using have exactly the same power specifications. Do NOT mix and match different types/colors of LEDs when wiring in parallel."
http://www.instructables.com/id/EVSO9B1KO5EV2Z9T0L/
Well if someone can give me a run down of what all the things I must have in order to make a flashlight with a high power LED, that would be great, and if people know of any battery configuration that could save me money on the parts list, that would be great also.
Chris
Chris
