Can\'t find a reflector for Mag85? Check this Out!
I was hoping to get a super Mag Mod quite some time ago. However, trying to get all the parts together from different sources is a big pain in the a$$. I think quite a no. of our fellow CPFers are still trying hard to grab, steal or rob some MOP reflectors. Couple days ago, I got some 3AA to D holders from Waion and I decided waiting no more and just went ahead to mod a Mag without the aluminum MOP reflector.
To start out, I bought an OSRAM Decoster 51 lamp ( 35W 12V 10 Degree ). I was tempted to buy the 50W lamp for the bigger output but I don't like the yellow beam.
Then I took apart a band new 3D Mag and cut out the top part of the switch assembly. With a little parts I bought from some hardware stores, I made that heat resistant switch ( Credit to CPFer KenHK who design this wonderful switch /ubbthreads/images/graemlins/tongue.gif ). The beauty of this new switch assembly is the bi-pin ceramic socket rated 100W @ 25V with heat insulated wire. Couple copper disc are also utilized for heat transfer to the Mag casing. Eventually, the residue heat conducted by the two screws ( further insulated by couple fiber corn rings )to the plastic switch body will do little or no damage at all. There is also no noticeable resistance found in this switch /ubbthreads/images/graemlins/grin.gif Another plus is you can adjust the focus of the lamp assembly by tuning the retaining nuts - No more out of focus lamps!!
Everything was put back together with the addition of a Borofloat glass lens.
The light output from the 35W lamp driven by 9 X 2100mAH Sanyo NiHM is No Joke /ubbthreads/images/graemlins/cool.gif The beam is amazingly smooth and white with no visible artifacts. I have no idea of the total output but it is certainly 3X plus brighter than my 130 lumen SF 9N. I don't have the runtime yet but my wild guess should be around 30 something minutes /ubbthreads/images/graemlins/blush.gif
The total cost of this super Mag is less than $65 and it is readily to be converted to a Mag85 when I can finally get an alum. MOP reflector.
All the parts required
The heat resistance switch assembly
The light engine with an OSRAM DECOSTER 51
The business end
Beam shot
The business end
Beam shot
