snipinglight
- Joined
- Sep 2, 2006
- Messages
- 168
How hard is it to drill and file these material? The same material they use in RC model helicopter and cars. I am thinking of making a 8AA to 2D battery adapter.
It doesn't come off as fibers in my experience, more like a fine powder. It sands like writing with a BBB pencil.Inhaling the fibers is a Bad Thing. Find out the necessary precautions and take them.
I am/was an aerospace composite fabricator.
Common drills will cause tearout and local delamination on CF/epoxy laminate. Our HSS and carbide drills were ordered/sharpened to a lower angle to reduce tearout. I can't remember the angle, but I might be able to find out if you need it. It was pretty shallow. They were also kept VERY sharp. Keep your piece well supported and backed with wood or other ablative material to reduce tearout. Clamp the part as close to the hole as possible or the sheet will lift and tearout when the drill penetrates. Very small delaminations around the edge of the holes are almost inevitable. They should be brushed with epoxy thinned slightly with some MEK. Use a cotton swab to wick MEK into the delams. The MEK will displace the air. Then immediately apply the thinned epoxy. As the MEK evaporates, it will draw in the epoxy.
Carbon Fiber reinforced plastic files and sands easily with common sharp files and fresh abrasive paper. It is not unlike other hard plastics like acrylic and polycarbonate. There is nothing about the carbon fibers that make it appreciably harder, just fuzzier. Break all edges to approximately .020". On very thin laminates, sand/file to round off the edges as smoothly as possible
In the form of a laminate like a thin sheet, either flat or formed, CF/epoxy is best milled with diamond abrasive tooling. It can be milled at fairly high feed rates provided the abrasive is sharp, and of adequate grit to prevent overheating as discussed by McGizmo.
Thicker products like compression molded parts and plates can be drilled/milled/turned using HSS and carbide tooling, but HSS will dull quickly and is not suitable for repetitive operations. Drilling and turning with solid tooling will create fuzz at the edges, but it can be removed with any file or abrasive product. All edges should be broken .020".
Diamond abrasive tooling is preferred for milling, but may be difficult in manual feed machines, as high feed pressures and carefully chosen feed speeds provide best results without overheating.
Vacuum is preferred to coolant because coolant will create a slurry of carbon/matrix that does not lubricate the cut, and may obstruct the flow of coolant to the cutting tool. In our shop, we never used coolant in any of our machining processes, but our enclosed CNC machines had to be vacuumed out, and the dust saturated oily muck from the automatic ways lubricator removed daily. The iolers were turnd up to prevent the buildup of dust on the ways.Our equipment utilized vacuum as close to the tool as possible to abate the dust.
Bernie
Well, you shouldn't breathe any non-organic dust, even plastic. BTW, I'drather have a facefull of asbestos than concrete dust.It sounds as bad as asbestos.
My post was way more thorough than snipinglight was asking for, but I copied that post from another forum. Sorry if I made it sound intimidating
There is nothing inherent to common carbon fiber product that makes it hazardous to work with. I only wanted to give tips that will produce the best professional results. Any material has its intricacies. If I made a similar guide to working with wood, it would seem even more difficult, yet wood doesn't intimidate most people. For instance, you can't use coolant with wood, and it will ignite at 450 degrees so you can't use abrasive tooling to cut it. And common metalworking tooling will tear it up. You need specialized tooling and tool speeds >20,000 rpm -way faster than most mills.
Common carbon fiber products are easier to machine than similar plastic products with the exception of minor delaminations which are easy to treat.
Bernie
