care and feeding of my surefires.
woodsman
Orange Park, Florida
I have a few heavily used surefires. I really haven't done much to dissasemble, clean, lubricate, and reassemble them. I've heard there are right and wrong lubes to use due to the o-rings on the lights. can someone please point me in the right direction or give me a few tips?
Thanks, jeff
this_is_nascar
Gloucester, New Jersey
You'll get at least a dozen different answers, so I might as well start. Don't waste your money. Go to Radio Shack and spend the $4.00 for the tube of their General All-Purpose lube. It will last you a lifetime and works just as well as the $40 per ounce lube that people are going to start recommending.
Skyline
New Jersey
I agree with t_i_n. The Radio Shack stuff has suspended teflon particles and it's really good -- it's very slick. It will not deteriorate the o-rings.
Some will recommend some very expensive lube (which I'm sure is very good...), but do you know how many o-rings I bought for just a couple of bucks? They cost pennies each.
fluorescent
I picked up a tube of Super Lube at my local Ace hardware...
Might be a buck or two more than the Rat Shack lube...
Their website is super-lube.com
From their site and back of the tube:
Super Lube Grease and Super Lube Oil with SYNCOLON® (PTFE) contain SYNCOLON® (PTFE). SYNCOLON® (PTFE) is the most slippery surface (lowest coefficient of friction) known to man.
- Highly lubricious, clear and non-toxic
- Excellent dielectric, impervious to salt water
- U.S.D.A. authorized, rated H-I
- Temp range -45F to +450F
Water & Saltwater Waterproof
More reliable lubrication and outlasts petroleum based greases and oils
Remains free flowing in freezing temperatures
Will not stain or harm wood, rubber, leather, plastics, fabrics and paint.
Won't drip, run or evaporate
Repels dirt, dust, grit and grime
Prevents rust and corrosion while reducing friction
Long Lasting
Compatible with conventional lubricants
Reduces friction and wear
Reduces Maintenance
Techmedic
Ajax, Ontario, Canada
Suggest that before you lube up, you disassemble and clean everything with isopropyl alcohol (drugstore rubbing alcohol for under $1) to remove all traces of dirt and old lube. Paper towels and Q-tips work well. For really dirty areas, use an old toothbrush, perhaps with a bit of soap and water or soaked in alcohol. If you had to use soap, rinse with clear water. Allow to dry, then lube the rings up, including putting lube into the channels where they rest. Re-assemble and wipe off the excess. Clean excess with q-tips and alcohol. Enjoy.
pjandyho
Singapore
As long as it is silicone grease it will do the job perfectly. I bought an Aquaseal silicone grease and my Surefire's 'O' ring have been functioning perfectly.
