wjv
- Joined
- Aug 1, 2012
- Messages
- 973
I recently bought a Wurkkos WK30 flashlight that takes a 26650 battery. While can charge the battery while in the light, I wanted to be able to also charge the batteries (I have 4 of them) outside the light so that I don't tie up the flashlight, using it as a charger. The batteries I have are the XTAR protected cells that are 68.2 mm long.
I have some Nitecore chargers (Intellcharger I2 and I4) but the batteries barely fit in the slots. They fit but I had to really force them in. If they had been just a fraction of a mm longer I would have needed a rubber mallet to get them in!
While t worked, I didn't like putting that much pressure on the button top and potentially damaging the battery.
Did some online shopping and found the Nitecore UM4 charger which was listed as handling just shy of a 80 mm battery.
I have to say it is a very nice charger. The display provided a significant amount of information on a slot by slot basis: Battery condition, Voltage, Charging Amperage and such. Most important to me, it really can handle the longer batteries.
Comparing the I4 and the UM4 side by side you can see the significant gap at the bottom where the UM4 can accommodate the larger cells. The contacts can slide all the way to the bottom of the housing. I measured the gap and it was ~0.4 inches.or 10-11mm in added length.
So if you are branching out into lights with larger cells as many of us are, the UM4 seems like a pretty good choice.
The only downside was that the charger only came with a USB-C cable but no AC wall charger. I solved that by buying a 3-pack of 3A USB Wall Charger off of amazon for $14. So there is no direct to AC connection like the I2 and I4 chargers.
