charger?
Definitely the Lacrosse. For normal use both chargers do the same job, they charge each slot independently and discharge, but the Lacrosse can tell you what it's doing on the screen, and can also report the figures at the end of a charge or discharge. You do need to set the charge rate each time with the Lacrosse as the default is to charge at 200ma whch is too low, but it only takes a moment to move it up to the 700ma.
BTW 700ma for AA, and on that charger use 500ma or maybe the 200ma for AAA.
