Cheap but decent-ish build quality USB-rechargeable light for home/garden/few trips
Prof.Dr.FlashlightNewbie
Hi,
I'm planning to buy something like a Nitecore MH12GTS for EDC, but first I wanna get a cheaper secondary light for home usage as my first "proper" flashlight.
I was looking at Amazon but with those cheap 20€ lights I'm kinda worried about their noname batteries exploding at some point. Previous cheap flashlights also broke.
Can you recommend me a cheap, USB-rechargeable flashlight from a trusted manufacturer?
Around 1000 lumens would be nice, but lower would also be ok. Most use will be at home and outside the windows, but I also wanna take it outside sometimes. Not sure how many lumens I actually want. Bright. xD
Multiple light levels. Memory mode would be nice.
Also it would be nice if it has that... "tactical" look to it. I know it sounds stupid, but I really dislike flashlights where the bezel is noticeably bigger than the rest of the light. Probably the least important aspect. I noticed the Nitecore NM01 as a cheaper alternative, but the non-removable battery is kind of a bummer, having to throw away the whole light if the battery wears out too much...
No idea what brands of flashlights are good either. Is Nitecore even recommendable? I have no idea what I'm doing, help. :p
==================Flashlight Recommendation Checklist================
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__✓__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
__✓__I don't know yet
____Up to $25.
____Up to $50.
__✓__Up to $100, but preferably much less...
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__✓__I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
__✓__SMALL - Every day carry (4-7 inches).
__✓__MEDIUM - Holster/belt ring carry. (>7 inches)
__✓__LARGE - Big enough to need its own travel case.
__✓__I don't know/I don't care.
5) Emitter/Light source:
__✓__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__✓__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
__✓__I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
__✓__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
__✓__I want a light with an integrated rechargeable battery pack.
__✓__I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
__✓__I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
__✓__I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
__✓__I want search and rescue type illumination (800+ lumens).
__✓__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
__✓__Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
__✓__Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
__✓__Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
__✓__Less than 1 yard/meter (reading, other close work)
__✓__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__✓__5-20 yards/meters (check out a noise in the backyard)
__✓__30-50 yards/meters (I have a big backyard)
__✓__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
____150+ yards (I am searching from a helicopter)
__✓__30-60 minutes (I have plenty of batteries just ready to be changed)
__✓__90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
__✓__Slightly Important (Walks around the neighborhood).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
__✓__I don't care.
__✓__I don't know.
____A simple on-off with only one output level is fine for me.
__✓__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
__✓__I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
__✓__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
__✓__Stainless steel (durable, but much heavier than aluminum)
__✓__Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
__✓__I don't know.
15) Water resistance
__✓__None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
__✓__In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
Would you like me to move this to "Budget Lights" subforum ?
Although that is usually for a budget under ~ $30-40, you might get more interest and advice with this topic there.
