Linger
Tragically, a WA1164 envelope failed, gasses momentarily very bright, quickly cooled coating bi-focal reflector. This was a seasoned bulb with a run-down 8AA pack. I had the light on for ~4minutes, it seems the bottom post of the bi-pin adapter had collapsed into the holder, the high-temp plastic now sticking out the top pushed the bulb out, sideways enough to contact the side of the bulb envelope reflector.
How do I clean the reflector? Alcohol bath? I haven't touched the surface, but it's all covered whatever cools from the gasses (tungsten?).
Thanx,
Ryan
- has anyone had their brass bi-pin adapter flatten on the bottom? It was in a resistance modded m@g switch. I suppose should put this in a separate post.
Thanx,
Ryan
