andrewwynn
Re: Programmable Incandescent Regulator 1 sign up-thread *accepting payments*
5V/470 = 10mA.. so with two parallel (5mA) might not be bright enough.. I actually personally would de-solder since with the 'talon' desoldering tool it takes less than 0.5 seconds to remove a 0603 device.. i only suggested tacking on 30ga wire as a thought because de-soldering a plastic SMD is normally a real piece of work.. it's nearly impossible to de-solder both sides to remove it. The MX-500 pays for itself daily! I used it about 20x yesterday to remove an 0603 capacitor to switch to a different value.
What i've been proposing is a mix of almost exactly those two concepts.. put the fiberglass 'wool' below a metal shield (since i'd be using with bi-bin bulbs).. I tried a test but made the bad mistake of trying to recycle some insulation that was previously installed in a house.. and it had DUST in it which instantaeously started to smoke! I plan to fabricate something out of tin or copper to make a conical heat-shield and put the fiberglass below that around the KIU. There can be no question that will help things.. normally i measure temps nearly 100C on the top of the KIU socket shortly after running the 62138 or 64625 lamp.
-awr
-awr
