Yeah, I've been kind of busy.
With regard to the school, those "supplies" may have been pre-Prop 13
, though I've seen both businesses and public agencies with similar emergency stockpiles that have been ignored for years. Some for lack of funding and in the case of the businesses, it's probably just not a priority issue. The same tends to occur with home "kits" that people may have assembled after Loma Prieta and haven't touched since. And of course, April is Earthquake Preparedness Month in California (coincides with the little tremor that occurred on April 18, 1906
Insofar as batteries are concerned, you're going to use them during normal circumstances anyway, so cycling them out of the storage kits each year or two also enables you get some use out of them for the money invested into them, while replacing the stash with fresh supplies, same goes for other perishables like the food.
I've seen some home kits that were assembled after Loma Prieta that have had MREs or MRE entrees in there for the past 17-18 years! Back then they were readily available rather cheaply near military bases with the entrees going for under $1 each. Saw another one that had bottled water from 1990, bulging cans of food, battery corrosion all over the box, and light sticks that were well past their prime.
In all practicality, I'd suspect that one would really be best served by just replenishing and cycling their supplies at regular intervals, just as is suggested for replacing the batteries in smoke alarms, rather than planning for long term storaged based upon their estimated useful life. It would be kind of disappointing to use 7 year old alkalines or 10 year old CR123s, just to find out that they have diminished capacity, in an emergency, after all those years of storage.
CHC said:
Thanks Brighteyez! Haven't seen you in a while. I'm guessing the company probably had a shorter life expectancy than their products eh?
We worked at one of the schools in Daly City and noticed one of the rooms had a storage shelter for emergency supplies and the like. Pretty much everything in there expired some 10 or more years ago! :huh: I saw firt aid kit supplies with early 1970s dating. Batteries were leaked/-ing and corroded. I wonder if anyone was supposed to be in that room, since it looked like it hasn't been opened since stocking of shelves!
I guess the alkalines and some lithiums may be considered the "best" choices so far for survival kits (earthquake kits in my neck of the woods) then.
Thanks!
