Comp-Tac Light Holder with Tek-Lok and Surefire E1B
Light Head
Anybody have this combination?
http://www.comp-tac.com/catalog/images/light_holder.jpg
http://www.comp-tac.com/catalog/product_info.php?cPath=23&products_id=30
I don't like the Surefire Holster.
How is the Comp-Tac Light Holder?
Is it secure? I called up the company, and they said they only have this one picture for their product. The lady said the 2 screws can be used to adjust the tension. Do the screws have to be adjusted regularly to keep the flashlight secure?
How is this Light Holder in actual daily use? Is it convenient, or too much of a hassle?
How much of the Surefire E1B projects above the Light Holder?
Is the Surefire E1B easily knocked out of the Light Holder? Do I have to secure the Surefire E1B with a lanyard?
I'm thinking of getting this with the Tek-Lok as I'm using a 2-inch belt. Is the Tek-Lok secure? Is the cantable angle useful?
Which model of the Comp-Tac Light Holder is compatible with the Surefire E1B? Comp-Tac Customer Service advised the Surefire E2D, as this bezel is supposedly the most similar to the Surefire E1B. Surefire Customer Service said the Surefire E1L is most similar to the Surefire E1B.
Inputs and comments appreciated.
E2D - I'd say maybe not.
E1L - maybe but not quite. E1B has a "melted" design. The lines are a little bit different.
Kydex's are molded into a specific item to achieve a perfect fit.
Thanks isneyk.
I was a hair trigger away from pushing on the BUY button.
The Comp-Tac lady said they do not know if they'll be making a Light Holder specifically for the Surefire E1B.
Any good holster for the Surefire E1B?
How about the Surefire E1B with the F04 Diffuser?
And the Surefire E1B with the E2D Tailcap?
I don't have a E1B or E1L(I wish I did), but I do have a comp tac light holder with tek-lok. Mine is made for the p series (specific 6P). It will hold securely my 6P, friend's G2, G3, and other P series lights. There is a single tension hex screw to adjust the hold. It holds it secure enough to where even if I run and jump and sprint, it will not move out. I have it attached to a strap on a bag.
The adjustable placement screw is like this:
X X X
--X--
X X X
in the back to have your light angled in a cant of your choice. The kydex is thick and solid, imo. I really haven't abused it though because it is on a strap not on person. From what I hear through, with rough use, the tek-lok is not ideal. I have the bezel down one, no idea why anyone would want a bezel up.
The design of the holder allows some small amount of light to leak out when you turn on the light while it is holstered. This has been the most suitable holder for me, so far.
I highly doubt, comp tac will make a holster for a light with a filter on it, for bezel down carry.
I think choosing the E1L would be better, because looking at the heads, the LED heads are little wider, whereas the E2D incandescent is all straight and little hex. With the CT design, it is not molded exactly to the light's bezel fit. It is molded to the width and will hold the light with resistance against the widest part of the bezel.
Bladetech is another kydex maker who makes light holders. They make horizontal and vertical holds. I had a G2 holder from them. Their plastic was different. Felt thinner, but I didn't have a lot of use with it. I traded it. This one has a closed bottom, no light leak. This might be important in certain situations.
Thanks for your input.
I can say that Comp-Tac makes an awesome product! I have not used their light holsters but their firearms holsters are top notch! The tensioning screws should allow a bit of room to play with size. You would not be disappointed. IMHO kydex holsters and light holsters are incredibly durable, functional, and last forever. Do not confuse quality kydex for cheaply produced injection molded plastic products.
Do you think the Light Holder for the E1L will be usable for the E1B?
They're not exactly the same...will the Kydex material have enough grip, given the differences?
The holster should find some points of contact for good retention with possibly some adjustment to the screws needed I believe the heads of both models have the same overall diameter but I could be wrong . Usually the good Kydex holders also have rubber grommets sandwiched in between the screws and the Kydex .But one thing also to think about which is important to some, though Kydex is smooth on the inside it could start to wear thru the HA finish on the light where it actually mates with the holder after repeated draws and reholsterings . And if you were to get any kind of abrasive debris inside the holder it will be brought to bear against the light during the draw and/or reholstering of the light. Just a cpl things to think about.
According to Surefire spec sheets the E1L &E1B are both 4" long and have a 1" bezel diameter. I'm not sure how they differ. Like previously stated...Kydex typically has a very smooth, non-abrasive inside (touching the weapon or light) and the outside will vary depending on the manufacturer or what is requested of you to the manufacturer. I have owned 5-6 different kydex holsters from Blade-Tec, Comp-Tac, and Sidearmor. I have and continue to carry some very expensive gear in these and have never noticed any wearing on the finish of anything. Is it possible...sure anything is possible. But my weapons and lights are used for working so they are well taken care of and not shelf queens! I ONLY use kydex holsters because they, if properly taken care of, will last forever. They provide a solid, stable platform to draw from, look professional, and are fast on the draw! Out of the 3 mentioned above I am a huge fan of Sidearmor. I think they, hands down, make the finest quality kydex gear out there!!! hope that helps
You had me at "professional."
I received a reply from Comp-Tac, basically saying that the E1L Light Holder can be used for the E1B.
Judging from the single picture Comp-Tac has on its website, 1-1/2 inches of the E1B will be held by the Comp-Tac Light Holder, leaving 2-1/2 inches protruding out from the top.
Is the secure?
I'm worried the SF E1B might fall out.
Will the 2 1/2 inch portion protruding above the belt interfere with normal movement?
I would think not! The light holster should have a rubber grommet or two. These, if needed, can be removed, cut down to 1/2 its size and then reinstalled. This will give you an even tighter fit if needed! E-mail Comp-Tac and ask if it can be returned if does not fit. I would check the fit before cutting those grommets though.
I haven't bought it yet.
I posted the reply I got from Comp-Tac, and my analysis of the single image they had of the Light Holder (http://www.comp-tac.com/catalog/images/light_holder.jpg).
Policetacteam, how do you think the Surefire E1B will ride in the Light Holder, based on the image? I estimated the size of the bezel, which will be in the Light Holder, and the remainder, and I think 2-1/2 inches will be protruding above the Light Holder.
I think if 2 1/2" is sticking up from the top would not be a problem. That's just my opinion. What works for me may not work for you! Is this light just for every day use or for duty. If its for duty I would think this is a perfect solution! I can attest to the quality of the product. Comp-Tac makes very high quality products. Kydex is so durable and it can take a hell of a beating. Most of my holsters have scratches, minor gouges, and other marks but they protect your gear and continue to work as good as new for numerous years. I think you're good to go!
Ok..I read back through the thread and in regards to the Tek-lok. I use belt holsters. Meaning my belt actually runs through the loops. Tek-lok works very well I just prefer belt loops because I think it provides a more stable platform to draw from. Both work equally well I just prefer running my Wilderness Tactical belts through belt loops. Plus I'm not sure what Comp-Tac means by "over-the-belt clip on design" I would double check with them. The way that is worded sounds more like a paddle holster design which I hate. Paddles are not a stable platform and, from the many DT / Firearms retention schools I've taught, have been continuously proven to be not safe. I have seen several different styles of paddles and I cannot think of one that I was not able to yank out or remove from someone with a little effort. I always have someone that shows up to DT class with one and that is the first person I call for a volunteer. People very quickly learn that these are not suitable for off-duty use and are even worse when you get into a fight for your weapon. Just my .02
I found out that I preferred the SF E1B with the F04 Diffuser on, so I have the F04 on both of my E1Bs. This makes it impossible to use the Kydex Light Holder (I hate taking off the F04).
I work in health care, and I feel this Light Holder might not be appropriate in my work setting.
Thanks to your input, I got a clear picture of how this thing looks and performs in use...instead of finding out after buying it.
