Compact-ish EDC light, 18350ish
bulldozer3
So ive been searching for my perfect light.... but each light has at least 2 shortcomings... for my first post here i figured i would toss it out and see what everyone comes up with.
Compact to midsize, single 18350, 14500, 16340 size.
700ish or so lumens on high/turbo.
1-ish lumens firefly/moonlight mode.
10-ish lumens on low (little higher is ok).
Direct access to moonlight from off.
Perfer it cycles moonlight-low-med-high and non-memory, but as long as i can force it to start in moonlight from off then mode memory is ok.
Clicky tail switch.
Non-magnetic.
Onboard usb rechargeable (usb-c preferred, micro usb ok).
Place to attach lanyard to wear around my neck.
Sent from my SM-G970U1 using Tapatalk
I would recommend the Thrunite T1.
Compact to midsize, single 18350, 14500, 16340 size. (Compact 18350)
700ish or so lumens on high/turbo. (1500 lumens on Turbo)
1-ish lumens firefly/moonlight mode. (Firefly: 1 Lm (14 days))
10-ish lumens on low (little higher is ok). (The T1 has ramping mode from 1 lumens to 685 lumens)
Direct access to moonlight from off. (Yes, can)
Perfer it cycles moonlight-low-med-high and non-memory, but as long as i can force it to start in moonlight from off then mode memory is ok. (The T1 has ramping mode from 1 lumens to 685 lumens)
Clicky tail switch.( ahhh.... T1 comes with side switch)
Non-magnetic. (T1 comes with magnetic tailcap) ...:(
Onboard usb rechargeable (usb-c preferred, micro usb ok). (comes with Micro usb)
Place to attach lanyard to wear around my neck. (yes, can be done)
And the T1 comes full package, with batt and usb cable.
Non-magnetic. (T1 comes with magnetic tailcap) ... :(
