Hello Avatar,
NiCd chemistry is different from NiMh chemistry. During charging, it doesn't heat up until the cell is fully charged.
Because of this, fast charging of NiCd cells and packs is often done at 2C, or sometimes higher, in performance applications. Your pack has 1500 mAh cells, so a good charging rate for normal charging would be 3 amps.
Battery packs can get out of balance, so you need to balance the pack with a 0.1C charge for 16 hours. This means charging at 150 mA. It is best to have a balanced pack, but fast charging gives you a bit of an edge on performance. This means that you have to alternate between the two charge rates. Usually you charge at the fast rate until you notice the run time falling off, or notice an individual cell heating up during the charge. Then you use the slow charge to balance the pack.
When storing the pack, discharge at 1C to 0.9 volts per cell and store the pack empty. If the pack is stored for an extended period of time (months), you may need to do a few charge/discharge cycles to bring it back up to peak performance. Every 30 days you should do a charge/discharge cycle, at 1C, on the pack.
This should keep your pack in tip top shape.
Tom
