TKO
- Joined
- Oct 21, 2007
- Messages
- 204
Five of these powering one of these in a 5D mag with AW's switch and any old reflector of the day.
Not the brightest light but here is my reasoning:
I already have a 5d mag and , yes, I do want a club. :thumbsup:
The 64440 only draws 5 amps when the 5D's settle down to 18 volts (predicted lumens 3776) nominal, so the runtime with a 4 ampHish battery should be 45 minutes or so on high and over 2 hours on low (predicted lumens 1132).
Bulb life is predicted at 31 hours at 18 volts, so instaflash should not be an issue with soft start.
So what I see is a very bright, usable patrol light on 30% setting that will last the whole shift while still having the ability to crank things up to over 3000 lumens when throw or shock and awe are called for.
Downside: Non-protected cells and battery charging will take forever:ironic:
Okay, with that said, feel free to crush my dreams and point out the flaws in my thinking and plans.:shakehead
