KC2IXE
I was doing some thinking today on "conventional wisdom" and milling machines
The conventional wisdom is that if you are slot milling, and need an accurate slot, you have to use a 2 flute end mill due to deflection of end mills that have More than 2 flutes
Today, we can use solid carbide end mills, and our mills themselves are often quite a bit more rigid than when the classic HSM authors were writing. How many of the old timers would have loved to have a machine as well built as one of our mill drills, never mind a Bridgeport (or better, a Bridgeport with ballscrews)?
I can't really see a solid carbide end mill "deflecting" enough to be measurable in the average shop
