Scattergun
- Joined
- May 9, 2006
- Messages
- 485
Just thought I´d shar this simple mod with you.
Started out with a Surefire G2 and wanted to have it run on cheaper and more readily available AA-batterys.
I took a DX LED-module with a Cree R2 inside and swapped the driverboard for one of the SKU7880 drivers.
After the driverboard was in place, I soldered a copper rivet to the center spring to make it about 15mm longer.
The DX R2 modules fit perfectly with no play in the G2 after the outer spring has been removed.
All I had to do was to cut a thin piece of rubber, roll it, and insert it into the body as an insulator
between the center spring and the metal cylinder on the inside of the body.
The rubber also acts as a holder for the smaller diameter AA-battery in the G2.
All in all a quick and easy mod!
