CPFReviews.com : NovaTac EDC 120 T Review Major Update....
ViReN
CPFReviews.com
This is a Review of Production version of NovaTac EDC 120 T, Full review is coming soon ;)
NovaTac EDC 120 T
provided for review by www.novatac.com
General Description:
NovaTac EDC 120 T is a Tactical Series flashlight from NovaTac. With single CR123 battery, Seoul SSC P4LED, Body built of aluminium and hard anodize type III, water tight with O-Rings, EDC 120 T is one of the brightest, very strong built, high quality, medium size light. EDC 120 T is one of the most advanced Tactical single CR123 light available in the market. The total output of the light is 120 Lumens, whense the name EDC 120 T. NovaTac EDC 120 T has Advanced (uC) Microcontroller Controlled Buck Boost Drive Circuit, this enables operation of the flashlight on both primary CR123 Cells as well as the Li-Ion Rechargable RCR123 Cells.
Light Features:
  • Can run on various CR123 sized battery ranging from Primary Lithium to Li-Ion cells
  • Toughened ultra clear glass lens with AR coating
  • Seoul SSC P4 LED
  • Buck-Boost Advanced Regulation (uC) Microcontroller Controlled Drive Circuit
  • Tactical Momentary Switch
Extreme Closeup ;)
More...
As soon as the Database and Other things are uploaded, I would be updating this tread....
Update 1: The Flashlight DB is now Up, you can now use the Compare Lights feature :)
I am going to add a few more comparisons and beamshots before proceeding to EDC 120 P's Review :)
Update 2: I was curious to see how the beam profile is in respect to throw and side spill... Here are the Smoke Shots, used help of fragrant Incense smoke sticks :)
The Angle of Spill is 56 degrees
The Angle of Main Beam is 4 degrees
Update 3: Updated Review with More Comparison shots and beam shots
Size comparison with Fenix P1 and Fenix P2D
Beam shot Matrix against Various Lights
More...
Re: CPFReviews.com : NovaTac EDC 120 T Production Version Review
thanks for the review! are you using a flatbed scanner for your close-ups?
my 120-p should get here tmrw., looking forward to playing with it.
A Seoul LED? Isn't it less durable than the Cree?
I haven't been reading the whole Novatac discussion, I thought they were going to use Cree... A little surprise for me.
"Toughened ultra clear glass lens with AR coating," from the review.
I thought these lights would feature polycarbonate lenses?
No I don't think it's Polycarbonate Lens, the Lens looks flat like glass, tapping it also makes sound like glass, there are no deformations what so ever, also there is an AR Coating looking very similar and much better to as compared with Other AR Coated Glasses. Normally, what I have observed is the Polycarbonate Lens is usually has very very slight budging/deformations, they sound like 'plastic' after tapping.
Not exactly a flat bed scanner but some of the components of that rig are similar to a "3D" scanner of a HP Multi Functional Device.
I just checked it again.... It is in deed Polycarbonate
:thumbsup:
Yup the lens is indeed polycarbonate :)
Update 1: The Flashlight DB for NovaTac EDC 120 T is now Up, you can now use the Compare Lights feature :)
I am going to add a few more comparisons and beam shots before proceeding to EDC 120 P's Review ;)
Re: CPFReviews.com : NovaTac EDC 120 T Production Version Review... Updated
The user manual says it is Polycarbonate lens with AR coatings. It does reflect an AR color when I checked it.
I'm not sure about this line in the review:
Below is the chart showing total output levels for various AA batteries in General Mode
If possible could you compare beams with a SF L1 cree and or a Fenix P1D cree/rebel?
Thank you very much, its now updated, :grin2: I forgot to update that from general review template... that's what happens when you review on a fast track and under excitement....
Thank you once again, it's appreciated :)
:( I do not have P1D CE or SF L1, but i can compare it with P2D CE and P3D CE which I have. I have planned for additional beam shots and will be updating tonight :)
matrixshaman yup, it is in deed, I was kinda confused when seeing such a flat and smooth and perfect (like glass) surface. The AR Coating reflects darker than other AR Coated lights that I have, a sign of good AR Coating i guess.
Re: CPFReviews.com : Novatak EDC 120 T Production Version Review... Updated
There is no doubt. The lens is polycarbonate. It has an AR coating. I often listen to how a "lens " sounds when tapped. If a 'lens is loose it has a much different sound. If you tap a glass HDS EDC it has a very distinct non sound almost muffled. Do the same with a novatac and the sound is very different it produces a much brighter higher pitched almost echo like sound.\
Maybe I will get around to recording these sounds for all to hear....one of these days.
I also have a very favorable opinion of the 120P. It is a very nice light. I will be changing out the "lens" with a UCL just as soon as the get here.
Yaesumofo
Tapping fooled me this time :whistle: or I need to check my ears ;) the sounds were almost same to me when i tapped EDC120T and Fenix P3D CE
:thumbsup: yaesu recording sound would be a great idea
Re: CPFReviews.com : Novatak EDC 120 T Production Version Review... Major Update
More...
Ack nice light, wish it was more P2D sized
