Nice heatsink, Jo. Two improvements would convince me to buy one if you make another run.
1. No milled extra pocket below the center of the emitter. Even though the MC-E's heatsink base is oriented 90 degress to it, there looks to be at least a 50% loss of metal to metal contact. Filling it with AA won't work as well as solid metal. I'd buy the heatsink with just this improvement alone.
The orientation of the second pocket was a fault as I mixed up the heat-sink orientation of the metal contact beneath the MC-E.
Question: Is there a reason for this pocket?
The reason for the second pocket space was intended for the heatsinking compound so that it would not "spill" over the 4 edges of the MC-E provided the correct amount is use. And that required a bit of work. It could have been easy for me to do without it and just merely mill out a square. But it was there to show the detail work given to design this heat-sink accordance to the MC-E architecture.
2. Four wire holes, one in each corner for 2S2P. Heavier gauge wire could be used since you wouldn't have to stuff two of them through one hole. Granted, leads between driver and LED will be fairly short, but I still like to use the heaviest wire wherever possible... especially with the high current as compared to single die emitters. It'll also look pretty cool with leads at all four corners. :cool:
The 4 holes idea was the initial thought. It is definitely more user friendly for the general public in term of choosing wiring configuration for the 4 dies with the MC-E. 2 lead holes idea for this prototype were chosen for the heat-sink to look simple and clean (the MC-E emitter is a fine piece of electronics minimization , and it is the attention of the whole light being the subject, visually it would be unpleasant to see so many item cluttering around it, holes, big gauge wires, big blob of solder etc...
Of course, the new design would be with 4 holes if this is what most people want.
A third idea for those who'd like to make the solder connections underneath the legs as you have, would be to mill some runners along the sides to provide room for the wires. It looks as if having them underneath the legs will prevent the LED's base from contacting the sink at all. No problem for me as I'll be soldering on top, but a nice option for others.
With 4 holes and a small gauge wire, it might not be necessary for the runners grove.
With some tweaks, this could be the perfect MC-E heatsink!
I believe it would be one :D
