op, i have 32650 protected and unprotected, but they are rated 5 ah, and have black wrapper, i have no complaints so far.
i also have 26650, unprotected, but they are different chemistry, and have orange wrapper, those too so far work fine.
these i,ve never seen before, nor heard of anyone using them, yet. but in general it is not a good idea to use li ion cells (li co chemistry) with no protection pcb, they might blow up, or discharge to the point when they wont take charge no more.
pcb's are cheap, also there are drivers that have low v cut off programed in them, so in that case it acts like pcb.
i use 4x 32650 protected in my 3xp7 light, and 7 26650 unprotected imr (different chemistry cells, safer than li co, they wont explode, but still are sensitive to over discharge), in 2 other lights.
few days ago i finished building a lantern with 2x32650 unprotected, but i bought protection pcb for around $5 iirc.
but i would not recommend use those cells you linked in series in multi cell light, unless you closely monitor discharge, cuz if one cells discharges fully, but others still had charge in them in series circuit weak cell starts reverse charging, and very good chance of it blow up, literally, with a boom. unless the light's driver has that cut off, or at least lets you know voltage is low, my l900 uses unprotected cells, but it starts blinking when voltage gets too low, if your light has that feature, than i wouldn't think twice to use unprotected cells.
i personally used many lights with multiple unprotected cells, from 2 to 56 in each, no explosions so far, but i never let them discharge too much,
