nailbender
D36 LED Drop - In modules - Red & Green DD available (For Surefire, Pila, Wolf Eyes)
Hi All
Here we have the long awaited D36 drop in modules for SF products and most flashlights that accept 36mm modules.
M series Surefire©
Pila© GL4
Wolf-Eyes© 9M, M90 products
NOW FITS Lumens Factory Seraph turbo heads.
-Unique Reflector Design
-Precision Machined Aluminum Reflector
-High Temperature Resistant Mirror Finished Coating
-All Modules are Pre-Focused for the Ultimate Spot (no doughnut holes)
-Compatible with all Flashlights with D36 Sized Reflector Modules
-New models that work with lumens factory turbo heads.
I will offer most of what leds that I have in my D26 modules thread.
These are 36mm and fit an M3 with the only adjustment being to drop them in and reinstall the Shock foam and rings. I have found that if you drop the module in and set the shock foam on top of the reflector and replace the two other rings as they came out and finish it with the poly flat washer that fits under the lens that the shock foam holds the module in place firmly and the bezel still screws in with out problem. I actually like the foam sitting on top of the reflector because this reflector has a lip built on the top of it that sits on the lower lip in the M3 head. This also gives a wider ledge for the foam to sit on top of. When sitting the foam on top of the reflector this then allows contact of the lip on the reflector to mesh and sit on top of lip in the M3 and hopefully pass a small amount of heat to the head.
This reflector is of substantial metal to help absorb heat.
I had no contact problem in a M3 when putting the module and light back together this way.
When installed the light turned on with no other adjustments to it and the module is firmly seated in the head.
Here are some pictures.
Reflector lip is clearly visible, this sits on bottom lip of head of M3
Emitter Side
Bottom side of module
Warm White MC-E beam shot
As mentioned above I will offer by order basically any led I offered in my D26 thread HERE There will be some limitations depending on battery configuration.
For 6 volt applications some levels will be offered depending on needed amperage of drivers.
For higher voltage applications at this time it is one level modules only.
Even though module costs were higher I am trying to hold costs to the same in most cases. In a couple leds they may increase slightly.
I will add to the list as I add new modules but here are a few offered. If you don't see something you would like please ask and I will build it up for you.
I keep most common leds offered in stock and most are offered in multiple bins.
D36 modules NOW IN SMOOTH OR MOP Smooth only available with whole modules. Reflectors only not available yet.
MC-E - MOP reflector 1 level modules 7.2 - 14volts
available in Cool White Mbin WG tint. Also offered in JE6 Warm White 4200K and Neutral white KA1 4900K
$65 shipped Conus
XP-E or XRE - MOP reflectors - 1 level module 3.6 - 18volts or 3 level (high , low , strobe) 3.6 - 8.4 volts
Offered in R2 bin WD tint. Also offered in AE5 warm white and Q3 5B neutral white.
$35 Shipped Conus
XPG - Smooth or OP reflectors / available in 1.4 amp 3 levels 3.6-6 volts / 1 level 3.6-18 volts @1.4 amps
R5 - cool white
R4 - daylight white 5000k
R2- neutral white 4000k
Q5 - warm white 3000k
$45 shipping included conus
More will be added later if not seen please ask.
HERE ARE NEW FIVE MEGA HOSTS THAT WORK GREAT
these are five mega products and extend run times and offer a great hosts for these great D36 modules.
They are offered here
Paypal information is in bio CC is 4%
Please post what you are ordering and CPF name in PP comments so I know what is what and who is who
Please post or PM for requests
Thanks
Dave
Hi All
M series Surefire©
Pila© GL4
Emitter Side
$65 shipped Conus
$35 Shipped Conus
R5 - cool white
Thanks
Dave
