Handlobraesing
Banned
- Joined
- Feb 14, 2006
- Messages
- 2,724
I no longer have my BC-900 as it's been replaced with a Maha MH-C9000
After having some experience with both, I'm comparing the two.
MH-C9000:
Four bays, AA & AAA
Charge up to 2A, discharge up to 1A, any config
Current setting is adjustable in 0.1A increments.
Functions
Charge only
Discharge only
Break-in
test (program in cell capacity in mAh, then it would test the capacity, takes about two days)
Cycles: repeat a routine you program in 1-15(12?) times.
one section display that rotates through each bay.
Backlit
When a cell is inserted, it would start as "1A charge". To do anything else, the user must manually define the function and parameters, every time, for each bay.
BC-900:
Charge up to 1A w/ 3 or 4 bays used. 1.8A with 1 or 2 bays used. discharge 0.5A
Available(charge): 0.2A,0.5A,0.7A,1A, 1.5A, 1.8A
discharge: 0.1A, 0.25A, 0.35A and 0.5A,
You can't change the charge and discharge independently. The charge and discharge ratio is always 2:1.
four section display that shows the selected value of all four bays at once.
Unlit
Functions:
Charge only
Refresh (discharge-charge-discharge-charge-discharge-charge)
Test: charge-discharge-charge
When a cell is inserted it would start at 0.2A charge. When multiple cells are inserted at the same time, changing setting affects globally. It is possible to set each bay to do a different function, but it is tricky as if you don't follow the procedure (which isn't in the manual), you'll affect the rest of the bays.
MH-C9000:
Four bays, AA & AAA
Functions
Charge only
Discharge only
Break-in
Backlit
BC-900:
Unlit
Functions:
Charge only
