Dereelight DBS V3 XP-G R5 (no more R2?)
beegee377
australia
Well, it seems that both XR-E reflectors and pills are available from Dereelight so you may still have a chance.
i looked at the website and the r2's are mentioned but not available ?
does any one know any more?
heater
Ann Arbor, MI
The dereelight is not regulated for the cr123's? That means starts out bright, and slowly goes dim, or stays bright until the batts. poop out? Thanks for the info, trying to suck it up!:popcorn:
heater
Ann Arbor, MI
Heater, out of the M20, RRT-1, and DBS, I only own the DBS (3 of them) so please take my opinion for what it's worth. You'd be doing yourself a disservice not keeping in mind that the DBS is a modular light that may come out with newer pills.
357mag1, what pill do you have on your DBS? I have an R2 (Q5) on it and it looks a lot cooler than beamshots I've seen while being compared to the Jetbeam and I was right, those beamshots are of a DBS with a Q2-5A. That's less brightness so I can't really compare.
I know the Olight isn't modular and I assume the Jetbeam isn't either. I'll be waiting for the newer reflector and pill to make the most use out of the R5 and/or ST90 pills (which haven't been announced, I'm just conjecturing!).
your right, didn't take the update ability into account.
jblackwood
Miramar, FL
I own three DBS's simply because I loved my first one so much. In fact, it was the first flashlight over $50 I got (so long ago now). Not my last for sure but aside from my DEFT, it's the only thrower I own. If you ask around here, I wouldn't be surprised to hear that many DBS owners didn't get another thrower class light after they got their DBS. Whether it's because they wanted to wait for the next best pill to make the most out of the upgradability or because it's just the best they've ever gotten, who knows? With me, I just couldn't see paying so much more money for another flashlight when a new pill may or may not be around the corner. There are lots of threads that say "buy it now otherwise you'll end up waiting for the next best thing forever," but I say why should you have to pay over $100 every time new LED tech comes out? Of course, that's just for the thrower class lights, in my case, since I buy P60 size hosts all the time and I missed the boat on the Javelin hosts . . . I was really eager to load a Malkoff into a body that can take AA batteries (I know it's not the first, but I like Dereelight).
Rant over. Phew!
imgadgetman
MD
I also have 3 Dereelights. My DBS R2 is perfect white and I can change it to MCE pill. I use my R2 with OP reflector to even out the beam and it doesn't sacrifice too much throw IMHO. I am waiting for the 3SM pill to come available as I only see 3SD listed. Jay, any word on the 3SM?
imgadgetman
FlashCrazy
Northern CA
Yes, 2 x CR123's would be regulated. Any DBS or CL1H that can use two batteries will be regulated. The 1SM-2 can also use a single 18650 (or two CR123's/RCR123's), but won't be regulated when using just an 18650. With 2 x CR123's or RCR123's, it will be regulated. The 1S is designed for only a single 18650, and is fully regulated with a single 18650. Clear as mud, right? :)
FlashCrazy
Northern CA
imgadgetman
The 3SM's are in stock, just not listed yet... will list them soon though.
To all: Please direct any other questions to my thread in the Dealer's Corner on CPF Marketplace. :D
heater
Ann Arbor, MI
Ordered my DBS R5 last night! Thanks for all the input all. Jay has been a good help so I got it from Flashlightconnection. Can't wait!:paypal:
Mr. Tone
Illinois
The service of flashlightconnection is as good as it gets. You will never regret being one of Jay's customers!
As far as XP-G R5 vs. XR-E R2 surface brightness difference, it would be cool to see if someone knows the specs of the two at the same drive current. I am sure that the XR-E R2 surface brightness would be greater than XP-G R2, but how much difference between the XP-G R5 vs. XR-E R2? Anyone, Anyone? Saabluster?
357mag1
Chesapeake, VA
I have the warmer (Q2-5A) pill in the DBS normally. I did put the R2 pill in the DBS and it still didn't throw as well as the RRT-1 but came closer.
bkumanski
SoCal
If you design a reflector for a new emitter, it'll be a great light if you know, what you're doing!
As for the throw however, I'm not sure that the XP-G will really be equal or better than the R2. I'm no specialist of those things, but I followed a few discussions about emitting surface and surface brightness. Someone claimed that the XP-G, even if brighter than the XP-E, can't throw better because the emitting surface is bigger and the surface brightness lower. As I said, I only repeat here what I read, I can't explain.
Though, I'm sure the new DBS is a better light overall Even if it lacks some throw, it'll have more than enough and the hotspot is bigger, it'll be a more universal light. on't get me wrong, I expect a thrower, but my Cl1H with the aspherical head throws also better than the DBS-R2, but its beam is awfull and there is no universality at all! :cool:
Is the emmitting surface larger? My XPGs are smaller than he XPEs, meaning a higher surface brightness, right?:shrug:
Mr. Tone
Illinois
The XP-G has a larger die than the XP-E, not the other way around. The XP-E has a higher surface brightness than XP-G with all factors being equal. They have the same footprint size but the emitting die is not the same size.
quasarba
The 18650 will give the longest runtime, about 3.5 hours, but will not be regulated... it will start out at full brightness but will gradually lose brightness as the battery's voltage decreases. When using two or more batteries, it will be fully regulated. The 1S version is the one to use for fully-regulated 18650 operation.
2 x 18500's will give about 2.2 hours on high, 3 x RCR123's will give about 1.2 hours. Brightness is the same, only the runtime changes.
The ad says the 18500 extension allows for much longer run times. Why go to this if the 18650 is longer?
bkumanski
SoCal
Maybe I'm missing something then. This thrunite xpg is smaller than the reflector opening, but an XRE fills it. Do the Xre's have a lens or something over it making it appear larger?
droeun
Thats exactly what i was looking for! Someone who had both. So Which one would you buy after owning both? Given quality, feel, finish, ect...? I ordered the rrt-1. Hoping there will be alot more throw than my m20 smo. Was going to do the dereelight, except for the change in emitters.
I had both but got rid of the RRT-1. It definitely threw farther with a smaller hotspot but was too heavy & bulky for what I wanted to carry around. The light just felt very slippery & unbalanced (top-heavy), I just find the DBS more usable.
Just my thoughts.
Mr. Tone
Illinois
Yes, XR-E come in a package that make it look larger. The XR-E and XP-E use the same die IIRC but come in a different package size and form. The XR-E has that reflective ring around it making it need a bigger hole in the reflector than XP-E or XP-G.
Mr. Tone
Illinois
Just my thoughts.
The size, shape, and performance of the DBS are great and well balanced to boot. It's nice to hear from someone that had the RRT-1 as well for the comparison.
Caroso
Sweden
I got my XP-G pill and reflector today.
It looks like it throws pretty good. It is very foggy outside, hard to compare.
The hotspot is bigger and the spill is brighter than R2.
The beam is ringy, worse than R2 version.
Lots of rings around the hotspot.
nnasko
Bulgaria
Hi all, I also have (had :( ) Dereelight DBS with the R2 emitter and I am planning to get the new one - XP-G R5 because something happened to my flashlight and it does not work anymore :(. Could somebody help me, how can I find out what is wrong with it? I mean - is it the pill or the switch button? I tried to connect the battery directly to the pill using wires and it did not work. I also measured the switch button resistance when it is switched on, and it was merely 4 Ohm, when it is switched off there is no electrical circuit at all, which I think is a perfectly right behavior. Anyway, is there a 100% sure method to check if the pill is damaged? Please help.
I want to get only the XP-G R5 pill + reflector but if the switch is damaged then I should buy a whole flashlight..
BTW, I just found some comparison between XR-E R2 and XP-G R5:
