THANK YOU BVH!!!!!!!!! That is precisely the kind of thing I was looking for!
I just dumped all my remaining 2 stroke oil into my fuel tank; that's the last of it I'll buy for diesel consumption! I'll be buying a couple more fuel cans that I can fill with B100 and leave on the truck as my new lubricity additive. I never get below 1/4 tank or so, so I could refill with petrodiesel and still have enough lubricity. But I have to run B10 during the winter and getting down to 1/4 tank of B10 and then refilling with straight petrodiesel could get me close to the line. Better safe than sorry, and biodiesel smells so much better when burning than even ULSD.
I used to run a diesel : two cycle oil mix ratio of ~60 : 1(~30 gallons diesel :1/2 gallon oil), which is very close to the 50:1 many small engine manufacturers recommend as a gas : oil ratio. That was my reasoning, if a mix ratio that rich will protect bearings and piston rings and cylinders running at high temperatures and 13,000+ rpms, it should protect my injection pump too(yes, I realize tolerances much are finer in an IP). Half a gallon is just easier to measure.
:buddies:
