I'm in the process of building a flashlight using a single 220 Lumen Luxeon K2 star LED and a Luxeon Buckpuck. (3023 series, 1000ma, external dimming), and 4 rechargable AAs. My hope was to connect a 5k potentiometer to make the LED fully adjustable from 0-100%.
The data sheet for the BuckPuck seems to state that this is possible, as one of its listed features is "optional external potentiometer intensity control (0-100%)" the BuckPuck is also available prewired with a potentiometer, which has "optional on-board trim adjustment (40-110%)" but I did NOT buy the prewired version, I bought the external pot. version.
Upon testing out the setup, I found that the 5k pot, when connected to the CTRL and REF wires on the Buckpuck, as recommended by Luxdrive, does not dim the LED down to anywhere near 0%. My guess would be about 60%, but it could be 40%.
The datasheet states that an on-off switch can be used externally on this model of Buckpuck in place of the pot, so that when the switch is closed and provides no resistance through the REF circuit, the driver turns the LED off. I tested this setup, and when I completed the REF circuit, the LED dimmed down to the dimmest it got when using the pot, but no dimmer and certainly not off.
My question: How do I get the pot to dim the LED through the full range of 0-100%, as opposed to the approximate 60-100% its doing now?
The AAs are fully charged, but being only 1.2v, add to 4.8v, slightly less than the stated Vin min of 5v. Could that possibly be reducing the range of dimming?
Am I right that placing the potentiometer between the BuckPuck and LED (which I have tried and does work to give a full range of dimming) would waste a good amount of power and create alot of heat?
And one more somewhat related question- does the buck buck drop the voltage by >2v or <2v? I know that it varies the voltage to maintain constant current, but I don't want to overpower the LED by inputting too much voltage into the Buckpuck. What's a safe Vin for the Buckpuck in order not to exceed 4v max for the LED?
Thanks so much for any replies!
